Import PST to Office 365 Tool
If you have PST file data and you want Import your PST file to Office 365 Account then you can take help of any third party tool that has ability to Import PST file to Office 365 Account. but In my Opinion you should use free trial version of this Software Regain PST to Office 365 Converter tool that Import single and multiple PST file to Office 365 Account in just simple and easy clicks.
You can try this Software free demo version from here:
https://www.regainsoftware.com/pstrecovery/import-pst-to-office365-tool.html
    The tool provides a simple and quick solution of moving the data of archived or local Outlook PST file to office 365 environment. You should try this ToolsGround Outlook to Office 365 Migration tool which allows users to import multiple PST files into different Office 365 accounts.
    More Info:- https://www.toolsground.com/outlook-to-office-365-migration/
    Try MailsDaddy PST to Office 365 Migration Tool solution to import PST file to Office 365 Cloud environment. With an easy and secure connection to Exchange Online in presence of the Internet, it effortlessly uploads Outlook PST data to Office 365 Platform. Supports all versions of Windows OS and Outlook data files. Embedded with high-tech features to provide accurate PST to Office 365 conversion.
    For more information: https://www.mailsdaddy.com/pst-to-office-365-migration-tool/
    With the help of WholeClear Migrator Tool for converting PST to Office 365 Converter tool. This software to convert all PST format.It is tool to Provide all services to convert PST files into office 365. This software is a Windows based tool and this software all Windows operating system such as Win 10, 8, 7, XP, Vista, etc.
    Visit here: https://www.wholeclear.com/migrator.html
    To migrate Outlook PST file data to an Office 365 Exchange online mailbox, you can use a manual process or third-party software. But one problem is with the manual method which is a complex and time-consuming process, it is not suitable for non-technical users. If you are a non-technical user, then you should use any proficient third-party tool. When I faced this problem, I used Bitacube Import PST to Office 365 Tool. This tool allows me to add and migrate multiple PST items in one click. Therefore, it enables the client to import several PST file items into Office 365 at once using a CSV document. You can check here this tool free trial versionhttps://bitacube.com/pst-to-office-365-migration.html
    edited March 2020
    GainTools Cloud Importer Tool rapid and stress-free explanations to Import PST to Office 365 with all attachments, contacts, calendars, folders, etc.
