Merge PST file
Is it possible to combine the contacts of the Outlook? If yes please advice.
  • Hi mona!
    Hope you are doing well!
    Nothing is impossible in this world, If you want to combine contacts of the Outlook then no need to worry, Just try PST Merge software and because this tool is loaded with three amazing options to merge Outlook PST files: Merge PST, Join PST and Merge Contacts.
    Hope this will help you!
    thanks
  • Mona,
    With Stellar Merge PST you can merge or join all data items such as Emails, Contacts, Notes, Calendars, Tasks, and Journals without altering the data of the original PST files.
    Let me know if that works for you.
  • Softaken Merge PST Software is a highly efficient program which merges multiple PST files into a single file. This innovative utility offers a cost-effective and fastest option to merge Outlook Contacts, Emails, Calendar, Journal, and other mail items into a single file without any loss in data.
    Salient features:
    High-speed merging process
    Remove duplicate items
    Merge only selected files and folders
    Retain original file structure
    Either exclude or include delete items
    Support Unicode & big data merge
    High-Quality compatibility
    Demo version to try
  • Hi there,
    Here, I am going to share one more solution which could be helpful for you to join or merge PST files. Read this post: http://www.bitdataconversion.com/merge-pst-files.html
    Hope it will help you.
  • Hi Mona,
    Yes, it is possible to combine contacts of the Outlook. For this, you have to use the third party tool PST Merger which can combine PST files along with the contacts.
  • If you want to merge PST files, you can use the built-in Import feature of Microsoft Outlook. By using this feature, you can import the mailbox data from two or multiple PST files into a single file. In this way, you can merge two or multiple files into a single PST file
    Visit at ; https://sites.google.com/view/combine-multiple-outlook-pst-w/home
  • To merge multiple PST files into single PST file, you can use Bitdataconversion Merge PST files software. It provides a safe and easy option to merge PST files without tampering any content.
    Read In detail: https://gust.com/accelerators/merging-multiple-pst-files-into-single-pst-using-pst-merge
  • The software can effective handle every Outlook items like Contacts, Emails, Calendar, Journal and other mail items into a single PST file without any changes in the original PST file. Have feature to removes duplicate items and excludes deleted items in the merging process. For more info. Visit here:-http://www.toolscrunch.com/mac-merge-pst.html
  • PST Merge software is a highly efficient program which merges multiple PST files into a single file.PST merge software can join password protected Outlook PST file.
    Visit here:- https://www.kdetools.com/pst-merge.html
  • Solving your query Merge PST file with the help of Merge PST Software with the help of this tool visit here: https://www.sametools.com/merge/pst/
  • Merge PST tool is used for combining multiple PST file into single PST file, It supports all the version of MS outlook including 2019 & other. The tool also has many features like remove duplicate PST file items while merging into single PST formats & you can also get a free preview for all your PST file before merging into a single file.
  • Merge PST tool is the best solution for merging various PST files into a single pst file, as we all know manual tricks takes a lot of time to merge file. But I am here with the blog which will solve your issue easily. just read the blog once.
    https://blogaryapriyanka.tumblr.com/post/185856897940/how-to-merge-pst-files-and-remove-duplicates
  • Yes, download this free PST Merge tool to combine the contacts of the Outlook. This is an advanced software that allows the users to merge multiple PST files into one PST without installing MS Outlook.
    Advanced Features:
    • Add various Outlook files into single PST.
    • Remove duplicates PST files while merging the batch PST.
    • Combine Calendars and Contacts of PST into new or existing PST files.
    • Joins multiple Archive and Password Protected PST files.
    • Supports ANSI and UNICODE PST Files.
    • Can work with all versions of Outlook and Windows.
    • The best features is that you can merge only selected files or folders by using a 'Selective File' feature.
    Download For Free: http://www.merge-pst.com/
  • Now you can use advance ToolsGround Merge Outlook PST Software that helps at the time when user wonder to access several Outlook PST files via one single file. This tool enables you to combine or merge large amount of PST files into one single file so that all can be accessed at a same time and without wasting time.
    More Info;- https://www.toolsground.com/merge-outlook-pst/
  • Merging multiple PST files into one is not an easy task for users. Therefore, to make it easy, you must try SysTools PST Merge Tool. It helps you to merge PST files together without any data loss issue. The software supports to merge PST files in Outlook 2019, 2016, 2013, 2010, and other versions.
    Free Download the Tool from here- https://www.systoolsgroup.com/pst-merge.html
  • To merge multiple Outlook PST file in single PST formats, you can get the help of Kernel Marge PST software. Try it: https://www.nucleustechnologies.com/merge-pst/
  • The Merge PST file is an advanced tool that can easily merge your unlimited files into a single file. You can select your files before merging them, and install them at existing PST folder or make a new PST file.
    Visit here:- https://www.mailsclick.com/merge-pst-file/
    Advanced Features:
  • edited November 2019
    **KDETools Outlook PST Merger Tools******
  • MailsDaddy PST Merge and Join Tool is an amazing tool that used to merge & join of multiple Outlook PST file into a single PST. It removes the duplicate items while merging two or more Outlook PST files. This single wizard application is compatible to combine password-protected Outlook PST files. The utility also helps to merge UNICODE and ANSI PST into Single PST file. This versatile tool easily installs in all Windows System and supports the entire Outlook version.
    For more details, visit here:- https://www.mailsdaddy.com/pst-merge-and-join/
  • If your pst files getting large then Splitting is the best option to reduce PST file size and to manage Outlook performance by using this outlook pst splitter software which split oversize Outlook PST file sized into small parts. The software has capability to split entire Outlook database like notes, task, journals, calendars, contacts etc. Visit here:- https://www.recoverfilesdata.com/split-pst-file-tool.html
  • By using this Regain Outlook PST Merger tool user can easily Merge their PST files into single PST file. this Software generates the progress report where you can easily see the progress report of all data before final joining.
    More info: https://www.regainsoftware.com/merge-pst.html
