How to Batch Print MBOX to PDF including Attachments?
in General
If you want to save & print multiple MBOX to PDF with attachments, then I would suggest you to use Indya MBOX to PDF Converter software. It is capable to batch print MBOX to PDF including email attachments.
Steps to Convert MBOX emails as PDF
* Download, install and run the tool
* Add MBOX files
* Click convert. All Done!
**Download Free Trial Version: **https://www.indyasoftware.com/dl/mbox-to-pdf-converter.exe
MBOX is a Mailbox format and PDF is document format. So here MBOX to PDF Converter is a highly recommended tool that would let you convert multiple MBOX files to PDF files with attachments and proper email formatting.
MBOX to PDF Converter will surely help you with this problem. You can easily perform the batch printing of the files from MBOX to PDF format that too with all the attachments.
MBOX to PDF Converter has some other advanced features also such as it is fully compatible with all the available Windows operating systems. This tool requires no Adobe Reader. It supports all MBOX based email clients such as Pocomail, Eudora, Mac Mail, Thunderbird, Postbox, Berkeley, etc.
visit:- http://vooksoftware.com/mbox-to-pdf/
When we convert MBOX files into PDF, the most important thing is keeping the email structure, formatting and attributes intact. And all tools CAN'T do that.
What every tool CAN do is convert batch MBOX files to PDF. What they CAN'T provide are:
1. Naming Conventions
2. Filters for Selective Conversion
3. Set Page Margins
4. Set Page Orientation
5. Set Page Size (Letter, A4, A3, etc.)
6. Ability to Include Internet Message Header
Try SysTools MBOX Converter and convert MBOX files into PDF documents with all the above-described options. With availability for both Windows & Mac, this tool will surely meet all your expectations.
For more info: https://www.systoolsgroup.com/mbox-converter.html
Here is another one software recommendation for you to easily batch print MBOX to PDF including attachments. It allows non-technical to easily migrate MBOX data files to PDF file format without any technical knowledge helps. It compatible with all the latest and below versions of MS Outlook and Windows OS including 10.
As we all know you can save your Thunderbird MBOX files as PDF format manually but if you want to move multiple numbers of Thunderbird MBOX to PDF format then you absolutely need of than third-party solution, so get the WholeClear MBOX to PDF converter program to convert MBOX emails to PDF format along with accurate emails formatting.
For more click here: https://www.wholeclear.com/how/take-printout-of-mbox-files-with-attachments.html
