How to Recover Corrupt PST File
PST is the most important file of Outlook, failure of PST means failure of Outlook and it is very important to repair and recover PST file. Generally, Users go for PST Recovery Software, however, if the software is not available then users must have the knowledge to retrieve the PST manually.
This involves two steps repairing the corrupt PST file and then recovering the lost File.
How to Repair Corrupt PST
Outlook has an inbuilt tool i.e. ScanPST.exe. This tool can be used to recover the PST file. Launch the software and add the path of corrupt PST file, and scan it for errors. If any error is found then click on Repair button to fix it.
Recover Lost data from PST: If all the data is recovered from scanpst.exe then it is good, else it can be obtained from OST or EDB file.
OST to PST
Create a new PST file from Outlook>> Account Settings
Now open the OST file and drag the data to new PST file.
The files available in OST when it last synced with PST will be moved
EDB to PST
There is another option to get the lost data from PST and that is from EDB file using Exmerge.exe. The Exmerge tool helps to export the Exchange Database Files to Outlook PST. Specify the location of EDB and export them to new PST and the files will be moved.
Thus with these manual methods, you can repair the corrupt PST file and recover data from lost PST file.
  • If you want to recover your damaged PST file then try Outlook PST Repair tool to restores all mailbox items such as Email, Calendar, Contacts, etc. from corrupt Outlook PST file.
  • Hi
    If you want to recover your corrupt PST file, try Outlook Recovery Tool for the quick, fast and best result. This software can save data into multiple formats like PST, MSG, MBOX, DBX, and EML.
    Thanks
  • When your PST files are become corrupted or damaged, then these should be recover soon. In case, of a severe corruption, you can try PST Repair Tool. This tool has the advanced mode to restore data when there is high corruption.
  • Hi sandycullen1
    As you above mentioned three different situations and its solution for the users, for that I would appreciate you. However, If you want to get one solution for all three situations which you define above, then you can try Exchange Recovery Suite tool. Read More: http://www.bitdataconversion.com/exchange-recovery-suite.html
  • To repair corrupted or damaged Outlook PST file, there are lots of professional software available on the Web. Kernel for Outlook PST repair is such proficient software, which can easily fix Outlook PST error issues and recover stored Outlook mailbox items within few clicks. For more information, visit: https://www.nucleustechnologies.com/blog/how-to-resolve-pst-corruptions/
  • Repair PST file with Inbox Repair Tool. Follow the below steps:
    • Locate and Open ScanPST.exe
    • Browse the PST file that you want to scan
    • Click on scan and wait for the process to complete
    • Once scanning get completed, Click on Repair to repair PST File
    • After repairing PST, import it into Outlook
    This is how you can repair your PST file with Inbox Repair Tool. In case if this does not work you can go for advanced PST Repair software like Stellar Repair for Outlook to repair and retrieves mailbox data from corrupt or damaged PST File.
  • Hi As long as they are not overwritten by anything new there, you often can have chances to take lost files back with formatted drive data recovery software, like DiskInternals Uneraser https://www.diskinternals.com/uneraser/ Just use related drive data recovery software to scan your computer drive and see whether it is workable for you. In the future, always prepare drive data backups on different devices well.
  • Suppose if PST file corrupted then you can use manual steps or you can use third party Software (Recovee PST Repair Software)
    Close Outlook.
    Open-File Explorer (Windows key + E).
    Browse the following path(where PST file is present)
    Inside that double click and run SCANPST.EXE file.
    If Manual steps not working then I will guide you to use third party Software Recovee PST Repair Tool.
  • Outlook emails clients additionally recover by accident deleted emails from PST report by using PST Recovery. Outlook e mail can use this software program to get better whole embedded email statistics items, which includes emails, attachments, images, zipped attachments, contacts, notes, journals, calendar alongside preserved e mail homes (like To, From, Subject, CC, BCC, Date, and Time), from a corrupt PST record. The tool permits customers to select more than one PST documents at a time to carry out batch healing. Also, it helps splitting PST documents into more than one parts. It supports PST documents created by way of any version of MS Outlook.
    Try Free Demo:- https://www.downloadtopten.com/recovery/pst/
  • Regain Outlook PST Recovery tool embedded with powerful algorithm and efficient to recover all emails data safely. This tool will Restore all email data as it was before corruption. This tool will not change the location of emails and file names.
    CheckOut this tool free demo version from here: http://www.outlookpstrecovery.emltopstutility.com/
  • Hi
    suppose you would like to recover your corrupt PST file then why not we should use the best software? Then you can try Outlook PST Repair for the quick, fast and best result. This software can save data into multiple formats like PST, TXT, MHTML, EML, RTF, MSG and many more.
    Thanks
    Read more: https://www.recovee.com/outlook-pst-repair.html
  • Outlook PST recovery tool is the best tool to recover all your deleted PST files. The Recovery Tool recovers all your deleted items within the file with all the exact emails and data. The Process grants the PST Recovery Software to perform the complete scan of the recovering data within the corrupted PST file. The software scans the damaged Outlook PST file item and recover, the “Inbox” or emptied from the deleted email folders.
  • I am suggesting you go for KDETools Outlook PST Recovery software. This software recovers corrupt and damaged PST file and also deleted folders; subfolder and attachments can be repaired by the software. Outlook PST Repair tool recovers Outlook Mailbox data Contacts, Journal, Calendars, notes etc. This software recovers any size of PST file 100% data recovery. This software support all versions of Windows and Microsoft Outlook.
  • PST is a personal storage table file which is used to store the emails, contacts an calendar and other items. But sometimes when this PST file corrupted the Outlook users has to face lots of problems in accessing their mailbox data. So the user can try Scanpst.exe to repair the corrupted PST files. But in case if the PST file is severely corrupted then the user can try Emaildoctor PST recovery. I hope this will help you in recovering your PST file mailbox data. For complete details check here:
    https://www.emaildoctor.org/deleted-emails/outlook.html
  • Are you unable to fix your PST errors with Scanpst.exe utility? It’s time to try the best Outlook Recovery tool for repairing corrupted PST files. The tool repairs your corrupt PST file within minimal time and all the mail items are recovered. You do not need any backup file for recovery and every email feature like emails, attachments, drafts, calendars, contacts, journal, tasks, notes are easily recovered. You can download this software from here: PST Repair
  • If you want to recover and retrieve corrupt PST file in original format then, you will need to use the best PST recovery software. It can easily recover data corrupt PST file without losing any item. Here is list of top PST Recovery tool: https://www.listyour5.com/best-outlook-pst-repair-tool/
