How to convert Thunderbird to Outlook
Somit_svkSomit_svk
edited July 2019 in Questions And Answers
If you are looking a best solution to export Thunderbird to Outlook then you can go with the SysBud Thunderbird to Outlook Converter that enables to completely export mail from Thunderbird to Outlook 2019, 2016, 2013, 2010, 2007, etc. It helps to export multiple & huge size Thunderbird files to Outlook at once. It smartly maintains meta-properties (to, cc, bcc, subject, etc), folder structure (inbox, outbox, sent items, deleted items, etc) & attachments. You can download demo edition and check out its efficiency without any cost.The demo version of this tool allows you to export first 20 emails from each folder.
To know more about the tool, please visit here:-http://www.sysbud.com/thunderbird-to-outlook.html
  • To move Thunderbird mailbox items to MS Outlook PST formats, you can get the help of a MBOX to PST Converter software. I would like to suggest Kernel for MBOX to PST Converter, try it: https://www.nucleustechnologies.com/blog/free-methods-to-convert-mbox-to-pst-file/
  • edited August 2019
    If you want to export your Thunderbird mails into PST format then, I would like to suggest try Shoviv MBOX to PST converter tool that easily exports your multiple MBOX files into Outlook PST format. The tool supports all Windows version as well as support 20 email clients for MBOX format such as Thunderbird, Eudora, Apple mails, Gmail and many others. Download a free trial version of this tool which converts the first 25 items/folder as well.
    For more info visit here: https://gallery.technet.microsoft.com/Best-MBOX-to-PST-converter-e009d3d4
  • If you are looking a dependable tool then MBOX to PST Windows is the highest selection to change MBOX to PST file in few seconds. It works effectively and safely on MBOX files and straightforwardly yields well-matched Outlook format for any version of PST Outlook.
    Read more: https://www.sametools.com/convert/mbox/
  • Here you can also try the A2Z Migrations for Thunderbird to Outlook, to convert the TB or MBOX file data to PST. This application is also reliable for all Windows OS like Win 10, 8.1, 8, 7, XP, etc and transfers the complete Thunderbird profiles data to Outlook 2019, 2016, 2013, 2010, etc in a few clicks. It also provides a demo version of the tool, you can download and use it to know all features or competency.
    Note: With the demo edition the user can export only first 20 items of all folders.
    Get more information about the tool by visiting: a2zmigrations.com/thunderbird-to-outlook-converter/
  • Move from Thunderbird mailbox data to Outlook PST is now easy with MailsSoftware Thunderbird to Outlook Converter. This Software provides an autoload option to add files to the Thunderbird user in a single click and designed with a simple user-friendly interface. It provides multiple export option to convert Thunderbird messages in PST, EML, MSG, RTF, HTML and MHTML formats. To know more information about the software visit: http://www.mailssoftware.org/thunderbird-to-outlook-converter/
  • If you are looking for a trustful and fast solution to convert thunderbird files to outlook PST format, then you should check any proficient third party tool. You can also check the manual method but the problem is that the manual method is a complicated and time-consuming process, it can increase the chances of data loss. When I had faced this problem, then I used Bitacube Thunderbird To Outlook Converter. This tool provides an advanced mechanism in the conversion process. But the graphical user interface has kept very easy to use for anyone. Due to these combinations now any use having or without technical knowledge can do their job.
    You can check here this tool free trial version: https://bitacube.com/thunderbird-to-outlook-converter.html
  • Download MBOX to PST Converter to convert multiple MBOX files at once in batch. This can be done by adding a whole folder comprising MBOX files. It is much capable of converting all different email clients like Mozilla Thunderbird, Entourage, Eudora, Apple Mail to MS Outlook PST file format. It extracts all the essential email components like To, Bcc, Cc, Sent, From, Received, Attachments, etc.
  • Thunderbird to PST Converter for Mac is not a simple task to perform on a Mac system it is a little bit different from others. The Mac user can take the help of the Thunderbird to PST Converter for Mac application for a safe and secure conversion. This software supports all MS Outlook versions like 2019, 2016, 2013, 2010, 2007. This application 3 and 4 Step to convert Thunderbird file to PST file. Thunderbird to PST for Mac User-friendly software easily operates by any user with basic skills of IT.
    Click here for more info:- https://www.mailvita.com/thunderbird-to-pst-converter-for-mac/
