Merge Outlook .pst files
Is there a way to merge .pst files? I just installed Office 2003 on a new
laptop and there were about 100 messages on the server, which made it into my
Inbox. I have backup mail files on an external drive. I don't want to
overwrite the new .pst file with the old one. Is there any way I can make a
single (merged) file?
  • You can easily merge the Multiple PST files into single PST files, I refer to third party tool is KDETools Outlook PST Merger. This Software has very powerful features:
    • It is easily removes deleted junk folders and duplicate items.
    • This Software supports ****password-protected**** in Outlook PST files.
    • It supports ANSI and UNICODE formats.
    • Merge the multiple PST file without installing MS-Outlook.
    • Merge PST files in all latest versions of Windows and Outlook.
      More Info: http://www.merge-pst.com/
  • edited November 9
    If you have multiple PST files and you want to merge them in one PST file merge multiple PST files. Merge Outlook PST tool to easily merge multiple pst file with a simple mouse click. It supports both ANSI and UNICODE PST file and merges multiple PST files in one PST file without any data loss. Visit here: https://www.softakensoftware.com/merge-outlook-pst.html
  • edited November 11
    The Merge PST utility is very useful to combine multiple Outlook PST files into a single file. It allows you to merge or join PST files easily without any loss of an email. By using Stellar Toolkit for Outlook, you can merge or join all Outlook items like Emails, Calendars, Contacts, Notes, Journals and Tasks. Moreover you can filter duplicate emails and save a new PST file to a new or within existing PST, Office 365, Outlook Profile and Exchange Server. For Free download the demo, check this link: https://www.stellarinfo.com/email-tools/outlook-toolkit.php
  • edited November 21
    If you have multiple PST files and you want to merge them in one PST file. Merge Outlook PST File to easily merge multiple pst file with a simple mouse click. It supports both ANSI and UNICODE PST file and merges multiple PST files in one PST file without any data loss.
  • I would like to suggest you safe and trustworthy Outlook PST Merge Tool for MS Outlook to easily merge or join multiple PST files in a single PST file which can be easily accessible in any versions of MS Outlook including 2016.
