MBOX Migrator Tool
MBOX Migrator Tool is the best toolkit to move all your MBOX data to another email client. It also allows user to convert MBOX file to your desired file format. It helps users to convenient to use or migrate to any platform they like. The best part of this toolkit is easy to use and compatible with all Windows OS like XP/VISTA/8.10. The toolkit saves all your data to your local computer.
If you want to convert MBOX file into Outlook PST format, you can use Mac MBOX to PST Converter, Using this application the large-sized PST file can be converted into MBOX format. The software provides secure and complete risk-free conversion of data. This software is affordable and beneficial for those users who want to convert Outlook PST data file to another file format. It supports all versions of MS Outlook and Mac OS.
For more information: https://www.toolscrunch.com/mac-mbox-to-pst-converter.html
For easiest MBOX to PST conversion, I would like to suggest a third-party MBOX to PST converter tool from Shoviv that provide an efficient environment where one can easily export multiple MBOX files into Outlook PST, Office 365 and Live-Exchange server in simple steps without any additional efforts. This conversion tool supports MBOX format over 20 other email clients such as Thunderbird, Seamonkey, Spicebird, Apple Mails, Gmail and many more. If you want a reliable conversion of MBOX then, you also go with this tool which allows converting the first 25 items/folder as well.
Get this tool from here: https://gallery.technet.microsoft.com/Best-MBOX-to-PST-converter-e009d3d4
WholeClear MBOX Converter tool export Thunderbird MBOX files to PST, MSG, NSF, EML, EMLX, TGZ, PDF, HTML, MHTML and also import Yahoo, Hotmail, Gmail, G Suite, Office 365 account.
Mail Extractor Pro is a tool which help you to convert your MBOX to PST. This tool comes with amazing specifications such as
1. In-Built file splitter
2. Supports all versions of outlook
3. Safe and secure conversion
4. High speed conversion
5. Auto-load of files
Read more: https://mailextractorpro.com/
You can try the MBOX to EML converter tool, for migrating your MBOX files. It's an advanced tool, that can migrate your whole data without any error and without making any duplicate data. It also supports the Windows OS like XP/Vista/10/8 (32 + 64 bit). This software is fast in the conversion of your data. The application always provides 100% accuracy in data migrating. It’s user-friendly software, so it’s easy to learn. You become familiar with this tool, after operating it 1-2 times.
Visit here:- http://www.download.adwages.com/mbox-to-eml-conversion/
Hello I am here to help you out from the problem your are facing to transfer the data from MBOX file format as there are many user who want to transfer there from MBOX to another format but don't know how to perform this exporting process. But for a direct and simple conversion you can try the Betavare MBOX Exporter Tool this application will provide you the accurate and quick migration solution for your problem in a simple manner. You can also try this tool by using its demo version and get more details by referring this link:- https://www.betavare.com/mbox/
