How to combine multiple PST file ?
Jamie_9Jamie_9
edited March 2019 in General
Can anyone suggest me the best tool used for merging multiple PST file to single PST file.
    If you want to merge PST files, you can use the built-in Import feature of Microsoft Outlook. By using this feature, you can import the mailbox data from two or multiple PST files into a single file. In this way, you can merge two or multiple files into a single PST file
    Visit at ; http://www.download.adwages.com/outlook-pst-merge/
    Try PST Merge Tool is the perfect tool to merge bulk PST to single PST file format. This software removes duplicate PST file while merging batch PST files. You can try this utility.
    More info visit here:- https://www.datavare.com/software/outlook-pst-merge-expert.html
    To combine multiple PST files into one, you can download SysTools PST Merge software. This will help you quickly merge multiple PST files into a single file along with emails, contacts, calendars, and other data items. It also helps you to remove duplicate items while combining PST files.
    Download Free Demo from here- https://www.systoolsgroup.com/pst-merge.html
    The advanced tool of Merge PST files can easily combine all of your PST files and you can easily install them at new PST folder or can create new PST folder. You can move your files before merging to one place to another place or folders.
    Visit here:- https://www.mailsclick.com/merge-pst-file/
    To combine multiple Outlook PST file, you can use Kernel Merge PST software. It can easily merge several PST file in single PST file. Try it: https://www.nucleustechnologies.com/merge-pst/
    Try Mailsdaddy PST Merge and Join Tool which quickly combined multiple PST files into single PST. This single wizard application able to search outlook data file from a particular location, as well as provide the facility to merge password-protected Outlook PST files into single PST. Apart from this, it allows skipping duplicate items while merging multiple PST file.
    for more details, visit here:- https://www.mailsdaddy.com/pst-merge-and-join/
    ToolsGround Merge Outlook PST tool is one of the best tools to merge PST file, with the help of this software we can easily merge files. This tool merges several Outlook files into one. It can also exclude duplicate PST files during a merge. We can get a free preview before merging the file into a single PST file. This tool merges Outlook PST files with all items such as notes, calendar, tasks, contacts, etc.
    More Info:- https://www.toolsground.com/merge-outlook-pst/
    Hello
    If anyone looks at the Best PST Software to merge several PST files then I would suggest trying to use the KDETools PST Merger. This Software easily merge multiple PST files into single PST files.
    Features are:
    • It easily merges various PST files such as calendars, contacts, emails, notes and all.
    • Merge PST file in ANSI and also UNICODE file formats.
    • There no file size limitation.
    • Easily merge password-protected files.
    • It removes the duplicate items.
    • Support all the Windows Version and Outlook Version.
    More Info: http://www.merge-pst.com/
    A simpler, quicker, and more efficient step by step guide to merge PST files manually. This Do-It-Yourself way allows you to easily merge PST files. You can use it to combine all data items such as Emails, Contacts, Notes, Calendars, Tasks, and Journals without altering the data of the original PST files.
    You can effortlessly combine your Outlook PST Files for trying many applications. But they all are not so secure and easy to access. I can give you the correct GainTools PST Merge Tool for combine your Outlook files.
