How to Convert VCF File into CSV Format ?
in General
I am looking to convert my vcf,vcard files into csv. I want to copy my contacts in .vcf format in my PC. It requires .csv format. How to convert .vcf to .csv?
Anybody help me.
Download VCF to CSV Converter is a software which is very fast and safe conversion tool , There is also no any size limitation . It supports in window OS including XP , Vista , 8 and 10 also , you can save your file in local drive , It gives Error free conversion from VCF to CSV format , You can try this tool.
More Info:- Download VCF to CSV Converter Software
your can try this:- https://www.downloadtopten.com/converter/vcf-to-csv/
