How can I Convert PST file into Other format?
By using this third party tool Regain Outlook PST Converter you can Convert your PST file to other file format like: MBOX, EML, MSG, EMLX, vCal, vCard and Office 365 Platform. this tool Maintains the original formatting of Outlook PST files. This tool Convert Outlook PST emails to other formats in just few clicks without any data loss. you can also try this Software free demo version and where you can also see the preview of all Convertible emails before saving.
Download this Software free demo version from here: http://www.outlookpstconverter.emltopstutility.com/
If you are seeking such a solution which can help you to convert/export PST files into Office 365, Live Exchange server, new PST, EML, and MSG, then I would suggest you try Shoviv for Outlook PST Repair tool. It will also help you to have PST data into HTML, RTF, Cal, vCal, and vCard format.
Zaplogix PST Converter tool is another proficient application to convert PST file into multiple formats without any data loss. https://www.zaplogix.com/outlook-pst-repair.html
PST to EML Convert Software consents you save emails in only EML file, when required. For data file of Outlook, the tool provides the file path to names PST and migrate data to individual EML file with all fields secured. To know more details: https://www.sametools.com/convert/pst/
There are various methods to export PST data to other formats. But I would like to know in which format do you want to export the PST data? If I will be aware of this then accordingly I would be able to suggest you and provide you the better solution.
Outlook PST Converter is a program that may be used to repair broken, corrupted offline PST file and convert offline PST file to new PST File without creating hassle. It is able to get better selective single and multiple folders and convert them into PST Outlook file, MSG, EML, EMLX and MBOX format with maintains folders structure. PST Converter Software efficaciously carry out conversion offline storage table to PST Outlook file with keep emails formatting and homes- to, bcc, cc, time, topics and from. It helps all MS Outlook variations included – 97, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
Know More - https://inspire-outlook-pst-converter-software.en.softonic.com/
You can use this software PST to MBOX Converter Tool. This application easily to convert Outlook PST file to MBOX file format. You can use this tool:- http://www.softwaretoconvert.com/pst-to-mbox/
PST to EML Converter for Mac is a very difficult task for all the users who are migrating PST file data into EML file, but it can be easy if you have reliable solution to use, sometime the data might get corrupt or damage due to hardware and software problem, improper shutdown of system and viruses infection. In such a situation use the PST to EML Converter for Mac, which complete scans the corrupt PST file for error and recover it very fast and also save their PST file into MSG, EML, and MBOX formats.
Visit here:- https://www.mailvita.com/pst-to-eml-converter-for-mac/
