NSF to PST Conversion tool
Use this third party tool Regain NSF to PST Converter Software and easily Convert your Lotus Notes NSF file to Outlook PST format. This is an advance tool works efficiently to move NSF file successfully to PST file against any obstruction. If you want to use this Software before buy this Software then you can also try this Software free trial version and In free trial version you can save 30 emails per folder at free of cost.
  • MailsDaddy NSF to PST Converter tool can easily and effectively convert Lotus Notes to Outlook with complete mailbox data items and doesn't lose its original formatting and properties. It produces an error-free result in PST file format that is easily importable in MS Outlook 2019, 2016, 2013, etc. The tool is single enough to export selected, complete as well as multiple Lotus Notes mailbox files in PST, EML, MSG, MBOX, Office 365, Live Exchange Server, HTML, MHTML, and RTF formats. Download the free version of Lotus Notes to Outlook Converter tool and check the features and functionalities of the software.
  • To convert Lotus Notes to Outlook use NSF to PST Converter Tool. It is an advanced application that easily imports all the mailbox data from Notes to Outlook PST format. It has a simple GUI Interface. The software easily performs without installation or configuration of MS Outlook. It is compatible with all editions of Windows OS and Lotus Notes.
  • edited December 2019
    Download SysBud NSF to PST Converter that recovers Lotus Notes NSF file and converts into PST file format. This NSF to PST converter supports batch conversion of NSF file into Outlook PST, EML, MSG, HTML, MBOX, Office 365, etc. You can select the email from Lotus Notes NSF file by check or uncheck process and safely export selective data of IBM Notes into PST file format. before migration, this professional tool shows the preview of all NSF data. As well as provides an option to export the large size NSF file into small PST file. The software supports all MS Outlook versions included- 97, 2000, 2002, 2003, 2007, 2010, 2013 and 2016 and lotus notes versions up to 9.1.
