PST Splitter to Divide Outlook PST files
in General
MailsDaddy PST Split Tool is an independent solutions, which easily split the over-sized Outlook PST file without installation or configuration of MS Outlook. The software provides 4 different option to split the PST file-
1. Split by date
2. Split by size
3. Split by folder
4. Split by email id
More info- https://www.mailsdaddy.com/pst-split-tool/
Split PST for Mac Software is an excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder, and email id, and defends them from any corruption issues because of file size limits. It is fully capable of splitting all MS Outlook items such as folders, journals, email folders. The application makes you sure that no actual data deleted during the process. This Software supports all Mac OS versions.
For more info visit here:- https://www.mailvita.com/split-pst-for-mac/
I will recommend you select one of the best determination i.e. Download Split PST Tool to divided Outlook PST mailbox. The software is so simple to try which provides the direct possibility to save complete Outlook PST format along with attachments.
There is another advance solution exists that you can use to break oversized PST file i.e. PST Split. It is simple to use, user-friendly and offers reliable functionality in splitting large PST file into multiple PST. The software launched with number of advance features for required output. Moreover, PST Split Tool offers 5 splitting options i.e. Split PST file by size, year, date, folder and email address and each option equipped with sub-options that a user can use accordingly to get the file as per need. Use the freeware edition of the application and split first 25 files free of cost.
