How Can I Merge two VCF file to Single VCf file?
To merge VCF files, you can try Merge VCF Tool. The software can efficiently process all VCF items, such as contacts, e-mail, and other items, in a single VCF file without any changes to the original VCF file.
More Info:- Download Merge VCF Tool
Hi...
on your issue. I know you must have to try a lot of software to many times. When I also was in trouble then I use this Merge VCF software suggested by my uncle. You can try this software and no need to convert one by one so you can save your precious time.
