How to convert MBOX to PST & import to outlook 2010/2013/2016/2019
  • To convert MBOX to PST file, you can get the help of a MBOX to PST converter software like Kernel for MBOX to PST file. The software supports Apple Mail, Entourage, Eudora, Postbox, Netscape, PocoMail, Thunderbird, Spicebird, Opera, PowerMail, Claws Mail, Evolution, SeaMonkey, Sylpheed, Mulberry, GyazMail, Gnu, Sparrow, The Bat!, WebMail. Try it: https://www.nucleustechnologies.com/blog/free-methods-to-convert-mbox-to-pst-file/
  • You can try MBOX to PST Free Download Tool. I’ve tried it and achieved the faultless consequences. It is actual guileless to try and enormously influential to transfer format steadily. No long progression; no hazard of data loss. Completely simple and straightforward resolution to move files.
    Visit here: https://www.sametools.com/convert/mbox/
  • edited August 2019
    To convert MBOX data into PST there is most feasible and reliable ToolsGround MBOX to PST Converter Software is available. Which help the user to migrate Thunderbird data to Outlook without any data loss. It also maintains data integrity after conversion.
    More Info;- toolsground.com/mbox-to-pst-converter/
  • Now, a safe and secure tool is available that is MBOX to PST Conversion Application
    which smoothly converts required MBOX files along with all emails, their components, and attachments. The tool allows you to save all files separately to PST format. I hope this tool showed a fully useful solution for you.
    Click here for more: MBOX to PST Conversion Application
  • Are you worried about how to convert MBOX emails to PST and import it into Outlook? Then, not to worry anymore. I would like to suggest you use MBOX to PST - a perfect solution to successfully export, convert MBOX files into PST file format which is well-suitable for all MS Outlook edition including Outlook 2019, 2016, 2013, etc. If you have any type of doubt, then you can try its free demo: Convert MBOX to PST
  • MBOX to PST Converter for Mac both are different file formats for storing mailbox database. Neither MBOX to Outlook PST provides any utility for converting MBOX to PST file format. But there is a manual trick that can easily export entire MBOX emails to MS Outlook PST. Through the manual trick you can export Lotus Notes emails to either Comma Separated value or Structured Text format. After exporting MBOX file data into these formats to MS Outlook PST format. Download the free trial version for MBOX to PST Converter for Mac.
    For more info visit here:- https://www.mailvita.com/mbox-to-pst-converter-for-mac/
  • Use this software to convert MBOX to PST to import to Outlook 2019/ 2016/ 2013/ 2010. The solution works perfectly fine and does not result in any kind of data loss.
  • MBOX is the file format that the mailbox represents. It is the most common file format used by many email clients, mainly Apple Mail, Thunderbird, Seamonkey, Netscape, Entourage, The Bat and many more. I would like to suggest here, one of the best tools that I used such as Bitacube MBOX to PST Converter. This tool successfully works under Entourage, AppleMail, OperaMail, Sylpheed, Pocomail, Gnu Mail clients, Mulberry, Mozillamail, Thunderbird, ClawsMail, Spicebird, Eudora, SeaMonkey, Evolution, Cone, Mutt, and Netscape email client applications. This Software supports all available MS Outlook Version like Microsoft Outlook 2016, Microsoft Outlook 2013, Microsoft Outlook 2010, Microsoft Outlook 2007, and Microsoft Outlook 2003. You can check here this tool free trial version: https://www.bitacube.com/mbox-to-pst-converter.html
  • Are you looking for the best migration tool to transfer MBOX data to Outlook 2010, 2013, 2016, and 2019? Then I am highly recommending to download MailsSoftware MBOX to PST converter tool. This is the best solution to easily convert MBOX to PST and EML, MSG, RTF format. The software supports all Windows OS. It converts multiple MBOX files data at one time and without altering in the original folder hierarchy. For more information, click here: http://www.mailssoftware.org/mbox-to-pst-converter/
  • edited December 2019
    Download:https://filehippo.com/download_mailsdaddy-mbox-to-pst-converter/
    This is a best application which easily exports single or multiple MBOX file into Outlook. User can use this tool on different type of MBOX/MBX and MBS based email client such as Apple Mail, Entourage, SeaMonkey, Eudora, Netscape, Gmail Webmail, Evolution Mail, Tha Bat and many more.. Another best part of the tool is that it allows us to migrate bulk email into Outlook PST format.
  • The easiest and simple Convert MBOX to PST with the advance MBOX converter software. This software scans the normal MBOX files and perform the safe and complete conversion of MBOX file into PST, EML, MSG, RTF and HTML files format. This MBOX converter tool also support all popular email clients application like- Thunderbird, Pocomail, AppleMail, Entourage, Spicebird, Eudora, , MozillaMail, Incredimail, Opera Mail, Evolution, etc. and convert them into an Outlook PST format. Securely migrates MBOX files data to Office 365/Exchange Server. For more information, see more at: https://www.mailsclick.com/convert-mbox-file/
  • Convert MBOX file PST file format by using this Regain MBOX to PST Converter Software. this Software also maintain the integrity of data and the hierarchy of emails folders.
  • Fast software to import MBOX to PST file format.
    • They are Support multiple MBOX files migrations at a time.
    • MBOX converter Support all MS Outlook versions and also windows version.
    • Allows check preview of mails items before saving.
    • MBOX files are used by some email services to migrate message databases, such as Google Takeout.
    • this software are support 20+email client applications.
    • Fast conversion in less time
    • It supports all Windows versions like 10, 8, 7, XP.
    More information: https://www.techbizy.com/how-to-convert-mbox-to-pst-manually/
  • use this mbox to pst to pst converter software as per my recommendation. By using this software you can Export email based information such as: messages, contacts, calenders and other items of Entourage, OperaMail, Thunderbird, MozillaMail, Spicebird, Apple Mail, Pocomail, Netscape, Incredimail, ClawsMail, Evolution, Eudora, Sylpheed, Mulberry, SeaMonkey, etc. email client application into an Outlook PST format. Visit here:- http://www.tools4recovery.com/mbox-to-pst-converter.html
  • In order to import MBOX files to PST format, I would like to suggest Stellar Converter for MBOX. With this MBOX to PST converter, you can easily export MBOX files to PST and various file formats. This tool also supports 17 +different email clients.
    Some important features:
    • No File Size Limit to import MBOX to PST file
    • Supports different MBOX email client like Thunderbird, Eudora, Entourage, Apple Mail and many other clients.
    • Import MBOX file to Office 365
    • Provides you the facility to check the preview of Scanned file.
    • Smart and profound feature of this tool make it user friendly .
    • Converts MBOX to Office 365, RTF, PDF, and HTML
    Note: This software has been recognized and awarded by many tech reviewers:
    http://comparecamp.com/stellar-converter-for-mbox-review-pricing-pros-cons-features/
  • Hi, you can use this Emaildoctor MBOX to PST Converter Software. This software provides the option to export the MBOX file to Outlook PST file format easily. For safe and reliable MBOX to PST Conversion the user can try the demo version of this software. https://www.emaildoctor.org/convert/mbox-pst.html
  • The best way to convert MBOX to Outlook 2013/2016/2019 is by using a smart and powerful converter tool known by a name of Mail Extractor Pro.
    Read more here: https://mailextractorpro.com/how-to-open-mbox-file-in-outlook-2016-outlook-2013-outlook-2010/
