Suggest the Best MBOX to PST Converter
2»
    To convert MBOX mailbox files to PST, use the following steps:
    1. Launch Kernel for MBOX to PST software.
    2. Select MBOX file(s) or add a folder containing MBOX files.
    3. Check the Preview of all mailbox folders.
    4. Choose the Output file format from the list of formats.
    5. For selective migration, use data filters by criteria.
    Hope this helps!
    Regards.
    MBOX to PST Converter for Mac software which can smoothly transfer or move all emails and other MBOX files of Apple Mail to Outlook PST format within few clicks. It provides you with a stop solution for the successful conversion of MBOX files of Apple Mail, Entourage, Thunderbird in Outlook PST file. These application conversions are very fast and quick. The easy to use application for any user. It also supports all MS Outlook and Mac OS versions. Download the free trial versions for MBOX to PST Converter for Mac software.
