Split Outlook PST file by using PST Splitter tool
in General
To split Outlook PST file into multiple small PSTs, use MailsDaddy PST Split Tool. It is an independent single wizard utility, which easily segment multiple PST files at a time without any error. It always gives 100% secure result. Any technical or non-technical users can easily operate the software because it has a attractive and user-friendly GUI interface.
More info- https://www.mailsdaddy.com/pst-split-tool/
Stellar Repair for Outlook allows a user to split the repaired Outlook PST into two or more smaller PST files. This feature lets the user to split the PST file based on Email ID, Date or Size. PST file splitting functionality comes handy if you want to reduce PST size. More details here: https://www.stellarinfo.com/advanced-outlook-repair.php
You can use Archive Wizard for splitting large-sized PST files in Outlook. Follow the simple steps as mentioned below:
Step 1: Start MS Outlook, open File >> Info >> Tools >> Clean Up Old Items
Step 2: Select a folder to Archive, choose a date to Archive older items and click
Browse to save the Archive file to the desired location.
With the help of this technique, you can reduce the size of the PST file and save older data items to the desired location one by one within Outlook and use them when required.
Regards.
Aby
O365cloudexperts
A few days ago I was worried about my large sized PST file but after splitting my large sized PST file with Split PST Tool Software that can overcome the problem in a few minutes. By using this tool I also get more options to split my large PST file. Large PST files can cause corruption, so its to split it in a smaller one. For splitting the large PST files Tools developers introduce a Split PST Software. It split your large PST database according to year, time, date and Size which helps in easy data accessing as it is managed in a better way.
Visit here:- http://www.download.adwages.com/split-outlook-pst/
You can Split PST Tool for the same. It is standalone application that offers 5 split options to split PST file i.e. allows to split PST file by size, year, date, folder and email address. Each split option equipped with sub-options that users can apply accordingly to get the desired output. Moreover, there is no need to worry about the data of PST file, it will remain intact and precise throughout the process. You can check the split process by downloading the free demo version that facilitate to split first 25 items free of cost.
Trying the demo version you can test their working and decide whether this GainTools Split PST Software Download is best you. One of them is the Split PST App.
Split PST for Mac software helps avoids large PST corruption issues by splitting and categorizing them in smaller sizes. It uses its own PST split to avoid the risk of corruption of PST files due to the issue of being over-sized. This tool is fully capable of splitting all MS outlook items such as emails, folders, contacts, calendars, journals, etc. This software supports all Mac OS versions. The software gives a secure and complete risk-free split of data. You can download the free demo version software.
Visit here:- https://www.mailvita.com/split-pst-for-mac/
