Tool to Migrate PST files to Office 365
Here is a best tool where you can easily Migrate your PST files to Office 365 Account in just few clicks. This Software can help you to easily migrate multiple PST files into Office 365 webmail including all emails, calendars, address book, notes, tasks, journals, and attachments in the same manner without any changes. User can use this Software free trial version and where user can also save 30 emails per folder at free of cost.
Download this Software free trial version from here:
https://www.regainsoftware.com/pstrecovery/import-pst-to-office365-tool.html
    Try another tool named Outlook PST Repair to import PST to Office 365. This tool will help you to import corrupted and non-corrupted PST files into Office 365, Live Exchange server, new PST, EML, and MSG in a hassle-free manner. It supports all the version of MS Outlook and Windows.
    Read More: http://www.bitdataconversion.com/pst-to-office365.html
    Hope it will help you to accomplish your job.
    I have used many manual methods but did not satisfied with any of the methods. Being a non-technical user, I first go through manual methods but to some issues, I found it not effective so I used PST to Office 365 and got best results. You may go for the tool.
    See here:- https://www.osttopstapp.com/pst-to-office-365.html
    Have a look here: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
    This is very informative article on OST to PST conversion methods. It can help you to convert OST to PST file without facing any issues.
    Have a look here: https://www.nucleustechnologies.com/blog/drive-shipping-method-to-import-pst-to-office-365/
    You can here a method to import PST file Office 365. may be it helps you.
    The tool allows for the faster conversion of data. Try MailsDaddy PST to Office 365 Migration Tool which consists of many features. It allows adding and scans the file giving the preview of the data. Exports either in primary or the archive mailbox. Creates a log file. There is no limit for the PST file size. Compatible with Windows and Outlook of all versions. Provides both the Demo and the Full version.
    For more info: http://www.psttooffice365.com/
    You can try ToolsGround Outlook to Office 365 Migration Tool software is an effective and easy to use software to convert Outlook PST to Office 365. This software converts multiple PST file to Office 365. Outlook to Office 365 migration software can migrate Outlook PST file. Outlook PST to Office 365 software migrate both ANSI and UNICODE file type.
    More info;- https://www.toolsground.com/outlook-to-office-365-migration/
    As well all know that there are so many software available in the market and if you are searching for the best tool then I recommend the A2Z Migrations for PST to Office 365. This is an advanced tool to migrate the single or multiple PST files to Office 365 Exchange Online environment at a time or parallelly.
    To get the complete details to visit: http://www.a2zmigrations.com/pst-to-office365/
    edited December 2019
    For effortless migration from the PST file to Office 365, you need a third-party tool. If you want the best tool, then I would like to suggest here one of the best tools such as Bitacube Import PST to Office 365 Tool because I had used this tool a month ago. It provides me fast and secures the migration of multiple PST files to Office 365 without any complex method. You can check here this tool free trial version: https://bitacube.com/pst-to-office-365-migration.html
    edited January 2020
    If you want to import PST data files to Office 365 Proficiently without any error or data loss. Use Shoviv PST to Office 365 Migration tool. The tool is properly able to import PST data to Office 365 and also able to import data in bulk and export it into Office 365 easily at the same time. It helps to import PST data to Live Exchange, EML, MSG, and HTML formats. The tool gives a guarantee to import PST data to Office 365 in an accurate way and without any data loss. It supports all versions of Outlook and Windows OS. Also, Mapping, Filter, and Split options available in this tool for your help. Download its demo version and check the features of the tool and import the first 25 data items per folder from this trial version.
    More details, visit:- Import PST to Office 365
    It also gives numerous import choices to save the PST file data to Office 365. For comprehensive information, the user can attempt the trial version of GainTools Cloud Importer Software.
    Do you want to import PST files to Office 365 ? Therefore, this great tool is recommended to restore PST to Office 365 Converter. This tool makes it easy to import PSTs into your Office 365 account with no file size restrictions. It also supports batch migration of folders. This tool supports all versions of MS Outlook and MS Exchange Server. The software interface is very simple and anyone can use this application without any problems. We strongly recommend using the free version to migrate mailboxes to the Office 365 platform.
    **For More Information Click Here: ** https://medium.com/@aishawinged/migrate-pst-files-to-office-365-f432d5480e47
