Best PST Repair Tool
With the help of PST Repair Tool, you can repair your PST file easily and save it in a new PST file and other formats also such as EML, MSG, RTF, TXT and MHTML. It is also capable to recover all the email properties including Cc, Bcc, Time and Date.
    edited January 2019
    If you are looking for the best PST Repair tool, I would recommend you to have a free trial tool with Shoviv Outlook PST Repair tool. It will help you to know about its features and workability.
    I had also faced that type of problem but I have found an good tool named as Recoveryfix for PST Repair tool to successfully resolve your PST related issues. It also supports all versions of MS Outlook and Windows platform.
    Outlook PST Recovery tool is an advanced utility that can be used by MS Outlook users in effectively repair your all Outlook PST file. It is capable of restoring all Outlook PST items such as emails, notes, tasks, draft, calendars, contacts, journal and all other items in PST file. Get more information, visit to:- https://www.downloadtopten.com/recovery/pst/
    This tool can fix all the problems on PST file and mailbox can be accessible in Outlook.
    Try this tool free demo version from here: http://www.outlookpstrecovery.emltopstutility.com/
    The inbox repair tool Scanpst.exe is the first aid kit for corruption in Outlook PST file. This tool is useful when PST file is corrupted error occurs.
    In such type of errors, Scanpst.exe is used. But when Scanpst.exe gets failed to fix damaged PST file then you can opt for full proof solution or competent tool. These tools are best alternative of inbox repair tool which easily scan severely damaged PST file & recover all mailbox contents. I’m sharing few tools list which is very useful.
    https://it.toolbox.com/blogs/janeparker/top-6-best-pst-file-repair-tools-for-all-ms-outlook-versions-093016
    In Outlook you have inbox repair tool which is also known as SCANPST.exe. This utility performs the scanning on the PST file and it also repairs the issues within the PST file. The minor issues are completely fixed by the scanpst. For major issues, the scanpst not responding condition can exist. For this situation, you need PST Repair Tool which can handle the scanpst not responding condition.
    you can download totally free outlook pst recovery software
    https://www.kdetools.com/pst-recovery.html
    ScanPST.exe is a free solution provided by Microsoft. Using ScanPST.exe tool, users can repair their PST file, but in some cases, it fails to repair corrupted PST files that's why users prefer third-party tool rather than a free tool. Read more https://outlookrepairtool.weebly.com/
    edited February 2019
    Use DataVare Outlook PST Recovery Tool is an excellent tool that can repair even the most severely broken PST file. This software scans corrupt Outlook PST file to recover them and restore all of them into new and accessible Outlook PST file. It recovers each and every detail in your data file such as attachments, emails, contacts, journals, calendar items and notes.
    You can try Scanpst.exe or Inbox Repair Tool of MS Outlook that works when your files are suffer from minor corruption. It will not recover your entire data as it is, for that you have to take help from third party tool. I would suggest you to give a try to PST Recovery software from SysInfoTools.
    PST file is an excellent file format to keep a backup of data. That's why we convert the data from OST to PST. But any computer suffers unforeseen damages sometimes and to protect your data from those damages, we use a PST repair tool to help us recover and repair the files and protect the data which we have worked hard on.
    MS Outlook PST file is a very sensitive file. If you do not open the PST file in a proper way, it may corrupt. So if your MS Outlook PST file has been corrupted then you can use Recovee PST Repair Tool. This tool can effectively repair your corrupted MS Outlook PST file.
    Extract all the deleted and corrupted Outlook PST mails. EMLmails Outlook PST Recovery tool restores Outlook Mailbox data - Contacts, Journal, Calendars, notes etc. The PST Recovery gets each and every bit of your lost or corrupted data. The Outlook Recovery is supported by the latest MS Outlook version like 2019, 2016, 2013, 2010, 2007, 2003, 2002, 2000, 98 and 97.
    For more information, you can visit our website: http://www.emlmails.com/pst-recovery/
    KDEtools PST recovery tool is the best Outlook PST tool used for recovering corrupted data. The Outlook data recovery tool recovers every bit of your Outlook PST files and emails with all the attachments.
    For more information, you can visit our website: https://www.kdetools.com/pst-recovery.html
    Zaplogix PST Repair tool is another effective solution which helps to repair corrupt PST file, recover the entire items and save into new PST without loosing or tampering any content. http://www.zaplogix.com/outlook-pst-repair.html
    Get the best recovery to your Outlook PST file without changing any formatting of data. Download the Free PST Repair Tool Easily.
    Outlook PST Recovery tool is one of the best software to recover and repair Outlook PST files. The tool offers multiple saving options such as PST, MBOX, EML, HTML. The software restores a large PST file that is up to 215GB.
    If you want more information visit -https://www.kdetools.com/pst-recovery.html
    parasbariparasbari
    edited July 2019
    If you're looking for the best Outlook PST repair tool, try Bitdataconversion Outlook PST Repair tool(https://www.bitdataconversion.com/outlook-pst-repair.html). This Recovery software is the simplest tool for repairing corrupted PST files, recovering and converting email data. This tool provides data security as well as integrity with speed.
    Recover all your corrupt or damaged PST files with the help of KDETools PST Recovery software. It helps users to restore Outlook Mailbox data - Contacts, Journal, Calendars, notes, etc. The PST Recovery gets each and every bit of your lost or corrupted data. The outlook Recovery tool is supported by all the latest MS Outlook versions like 2019, 2016, 2013, 2010, 2007, 2003, 2002, 2000, 98 and 97. The tool has a simple graphic interface so that anyone can operate it even without having any technical knowledge. You can also export recover PST file into multiple file formats like new PST, EML, RTF, Office 365, Live Exchange Server, and etc.
    edited August 2019
    @george123 said:
    MS Outlook PST file is a very sensitive file. If you do not open the PST file in a proper way, it may corrupt. So if your MS Outlook PST file has been corrupted then you can use **Eelphone PST Repair . This tool can effectively repair your corrupted MS Outlook PST file.
    Ok, from all above, just this tool worked to repair corrupted PST files.
    "Best" is too mainstream. What works best for one person may fail entirely in the case of another person. That's why it is better to test the product for performance and accuracy first.
    Almost all the PST Repair solutions are available on a free demo version basis. So you can download the demo version and view how much data is recoverable.
    Try this one: https://www.pcvita.com/outlook-pst-repair.html
    It will certainly repair your file and recover all the underlying content including emails, contacts, calendar, tasks, and notes.
    edited November 2019
    vMail PST Repair Tool is one of the best software to repair corrupt PST file and recovers lost Outlook emails, contacts, calendars, tasks, notes, journals, etc. This tool can also convert pst file to many formats like MSG, MBOX, HTML, EML, PDF, RTF, etc and also directly export recovered mailboxes and other data to Office 365.
    Read More- Outlook PST Repair Software
    Use Zaplogix Outlook PST repair tool is a software for repairing or recovering your damaged PST data files. This application has many function that focus on data integrity and accuracy while the processing of data.Just you have to pay USD 49 only For Home License.
    Visit Here: https://www.zaplogix.com/outlook-pst-repair.html
    Stellar Repair for Outlook is an advanced PST repair software for instant restoration and repair of a corrupt PST file. The powerful scan engine of this tool can parse severely corrupted PST file of any size to recover mailbox data including deleted emails, contacts with 100% integrity and precision. This smart tool allows you to save recovered mails in multiple formats like EML, MSG, RTF, HTML, PDF, DBX, MBOX and Office 365. Moreover it supports Outlook versions from latest 2019 to all the way back to 2000.
    You can try the PST Repair software by SysInfoTools. This is a great tool that can perform safe repair and restore Outlook PST Files.
    Visit: https://download.cnet.com/SysInfoTools-PST-Recovery/3000-2369_4-76150230.html
    Try this Regain Outlook PST Recovery tool and easily Repair your corrupt PST file and Recover your all deleted PST file data.
    There are available many Outlook PST repair tools to repair damaged and corrupted OST file. But all application are not worth for using it. You can easily recover lost Outlook PST data items such as emails, contacts, tasks, notes, etc. by using this professional application. So, the list of best 5 PST repair tool are given below:
    1. SysTools Outlook PST Recovery Software
    2. Kernel for Outlook PST Repair
    3. Stellar Repair for Outlook
    4. PCVITA recover outlook
    5. Datahelp PST Repair Wizard
    Source: https://www.listyour5.com/best-outlook-pst-repair-tool/
