Hi, if you want to convert OST file format to PST file format then I suggest you to use this application. This will help you to perform the OST to PST file conversion process in a safe and reliable manner. https://convertostpst.org/
If you are looking for the best free tool to convert OST to PST files, try DotStella Outlook Email Forensics Wizard. If you want to transfer or move OST files in PST format with attachments, you can quickly try this utility with a free trial version.
DotStella OST to PST converter has the following characteristics
If your OST data is corrupted and you Looking for OST then PST converter tool on Google to recover OST data. So I want to give you the information about the best OST to PST tool, which I have done it myself, this tool scans your OST data deeply and changes it to PST and this tool will convert your OST data, EMLX, MBOX, MSG Changes to and EML etc.
