Reliable OST to PST Converter
OST file is one of the database files used by Microsoft Outlook. Its main purpose is to serve as an enabler for working offline even when the connection to Exchange is not live. In such scenarios, the changes you make are later synced to the Exchange Server when the connection is back live.
If there are any errors or corruption issues in the OST file, the information stored within it comes under risk. This is mainly due to the fact that OST files, unlike PST files, cannot be opened independently of the Outlook profile that created them.
So in all such scenarios, what we need is a tool that can Convert OST file to PST. The resultant PST file can then be easily imported into any version of Outlook and its contents viewed. To accomplish this, you will need an tool that can easily extract all the information from within your OST file including mails, calendar, tasks, journals, contacts etc and flawlessly convert it to Outlook PST file.
EdbMails OST to PST Converter tool with its simple to use user interface can accomplish this for you. Along with support for most versions of Exchange and Outlook, it also supports 64 bit windows operating systems. What’s more novel about the OST to PST tool is that it allows direct OST migration to Office 365 as well as Live Exchange Server.
EdbMails preserves the folder structure intact and also lets you view all the contents of the OST file within the application. There are extensive filtering options by date, subject, attachments etc that you can apply to the mails before export to PST file.
    If you are looking for a solution to convert OST file to PST format, you can get the perfect conversion mode in this article. DotStella Outlook Email Forensics is the best tool to solve this problem, because it directly transfer bulk of OST data items into Outlook PST format with all email attachments. With this software, you can easily export .ost files to your Outlook 2019, 2016, 2013, 2010, 2007 mailbox without losing a single bit of information.
    Are you looking for a Mac OST file to PST file format? You can try this application to migrate the OST database file to Outlook PST file format. It can convert multiple mailboxes that contains inbox, outbox, sent-items, deleted-items, drafts, notes (to, cc, bcc, subject, date and time). This software easily recovers corrupt OST file. You can download the free trial version for OST to PST Converter for Mac Tool.
