How to import Zimbra to PST
If you want to import Zimbra to PST then you can try professional software like Zimbra Converter. The software easil6 import Zimbra file to PST and Various file formats such as MBOX, EML, EMLX, HTML, PDF, NSF, OLM, and etc. The software maintains metadata of email such as to, bcc, cc, subject, date, attachment, and etc.during the conversion process. The application allows the user to check the preview of the email with an attachment.
Read More: http://www.zimbra-converter.com/info/top-5-zimbra-converter-of-2020.html
You can easily import Zimbra to PST then I would like to suggest a third-party tool like KDETools Zimbra Converter. The software safely import Zimbra to PST and multiple file formats such as EML, NSF, MBOX, OLM, EMLX, HTML, PDF, and etc. The software also import Zimbra Contacts and Calendar to PST. The application maintains folder structure and metadata of email during the conversion process. The software is compatible with all the latest and oldest versions of Windows such as Windows 10, 8, 7, 2000, XP, Vista and etc.
Read More: https://www.kdetools.com/blog/zimbra-mails-converter.html
