How to Export PST to TXT?
in General
You can easily export PST to TXT file format by taking the help of Outlook to Text Converter. The utility save multiple Outlook emails as Text file with their attachments without altering the information data. It is totally supports all version of Microsoft Outlook like 2019, 2016, 2013, 2010, 2007, etc. and it also compatible with all Windows version.
Process to Export PST File to TXT
- Select .pst files
- Choose output folder location
- Select desired file naming option
- Press the convert button
Know more info:- https://www.indyasoftware.com/blog/convert-pst-to-plain-text-file/
Download Extract TXT Attachments software to extract TXT from Outlook PST, extract Contacts from Outlook PST, Extract emails address from Outlook PST TO, CC, BCC. Download Free Tool for Windows with Outlook 2016 to 2003. Outlook PST extractor software makes resolve the PST oversized issue. This software easily extracts outlook attachment of any outlook version.
More Info:- https://www.softwarewiki.org/topic/how-to-save-txt-file-from-multiple-outlook-emails/
I tried to find a free way. Unfortunately I have not found any manual trick or technique. Take the help of the DotStella PST to Text Converter application. This tool is designed to export Outlook PST emails to txt file format. The plus point of this tool is that there is no any file size restriction.
**More Info: ** https://www.dotstella.com/file-converter/pst.html
