Migrate OST to Office 365
Through OST to Office 365 Migration tool you can easily Migrate OST to Office 365 A/C without missing any items of OST files. This software can show you the preview of the conversion before the conversion is done. You can convert your data into various formats like Office 365 Gmail, Zimbra, OLM, NSF, PDF, PST, EML, EMLX, vCard, vCal, MSG, and MBOX, HTML, and, etc. Try the free demo version of the converter to know more about the features and functions of the converter. With the help of the demo version, you can convert 30 data for free.
Feature facilities-: For **Migrate OST to Office 365
• Split large size of OST files by Date
• Messages Filters by Date, Contacts, and Size).
• Batch Conversion option to Selects multiple OST items.
• Convert OST to Office 365, PST, MBOX, Zimbra, Live Exchange, OLM, PDF, NSF, PST, Gmail, MSG, EML, EMLX, and etc.
• Import OST Contacts, Calendar items into vCard/vCal file formats.
• Export OST data into Office 365 inducing Emails properties- To, Subject, From, Date, and, etc.
More Info-: OST to Office 365 Migration
Comfortably move OST data file to Office 365 without any issue with the help of MailsDaddy OST to Office 365 Migration Tool. It never allows changing any single OST item and maintains 100% data accuracy. Simple to use software with numerous useful options.
Read more: http://osttooffice365.com/
You can download OST to PST Converter for Mac Tool. This software easy to convert OST file to PST file format on Mac. The OST to PST Converter Software can easily maintain email folders to restoring CC, BCC, To, From and attachments. It is a simple wizard that is easy to use for any non-technical user who wants to save OST files into Outlook data file format. This application recovers and corrupt OST database file. It effectively works on such all MS Outlook versions up to 2019 and also supports all updated Mac OS.
After converting OST files into PST, Upload to Office 365
It is the indirect method to convert OST file into Office 365. First import the OST files to PST format, after that you need to upload PST file into Office 365.
Step 1: Convert OST file to PST file
Open your Outlook account >>file >>import and export.
Select Export to a file and click on Next
Then go to Personal Folder File (.pst) >> Next
Now select email or folder, check on Include Subfolder >> Next
Browse the location where you want to save the file and check “Replace duplicate with items imported” and click Next
Put the password (if you want, otherwise skip it) and hit Ok
Note: If the exchange server is offline or you are not connected to the server on this time given method will not work then simply use the OST to PST converter tool for exporting OST file into PST format.
Step 2: Migrate PST file to Office 365 cloud platform
Login your office 365 account >> Admin Center >> Exchange
Exchange Admin Center window will appear>> Permission>> double click on Organization Management a new popup appear >> + sign >> select Mailbox Import Export >>Add>>Ok
After that select Mailbox import export again >> Save
Now go to Admin Center>> Setup>>Data Migration >> click on Upload file.
Then hit on New Import Job>>type the job name >> Next
Check on Upload Your Date>> Next.
Now you will see a window just click on and Show Network Upload SAS URL copy the URL & paste on the notepad >> Download Azure AzCopy click Run and the tool get installed.
Note: while you are importing PST file to Office 365, just give the permission of the folder or file which one you want to import and copy the Network Path.
Open the Microsoft Azure AzCopy tool and type here
AzCopy.exe /Source: Network Path or File location /Dest:”SAS URL” /V: location path where you want to save log file /AzCopy.log /YSample Code:AzCopy.exe /Source:\DESKTOP-MPKVU38UsersleDesktopImport /Dest:"https://476d07f3b7d444a7a00a5a7.blob.core.windows.net/ingestiondata?sv=2015-04-05&sr=c&si=IngestionSasForAzCopy201806090656050007&sig=hccYVWvlkOhp6FISVYywwt9W9YlzRoQfXqGZvq14jqM=&se=2018-07-09T06:56:09Z" /V:c:UsersleDesktopAzCopy.log /Y
Press the Enter key
After uploading PST file, create a CSV file to map PST fine into mailbox account.
Now open the import data window and check on both option and >> Next
Click on Select Mapping file>> Upload CSV file>> Validate>> Save
Your PST file successfully uploaded into Office 365 >>Close.
Aby | o365CloudExperts
