How do I convert csv file into vcf/vcard format?
I would like to convert my CSV into a vcf file format, I don’t know how to that convert if you know. If anyone knows,
plz, help me.
If you are not able to convert your CSV file into VCF format then you can use CSV to VCF Converter software, help you to convert contacts from CSV to Vcard file format.
More Info:- Download CSV to VCF Converter
In case if you want to convert spreadsheet into CSV to VCF format. you can use this CSV to VCF free converter software that's easily & safely convert data from CSV to VCF format. This is the best tool to convert spreadsheet file without any mistake & 100% accurate. i also used this conversion tool.
Try now.
