Video Capture with Holograms in Unity
Hello,
I want to record mixed reality video in unity.
I already tried using VideoCapture (https://developer.microsoft.com/en-us/windows/holographic/locatable_camera_in_unity).
but hologram is not appeared even if cameraParameters.hologramOpacity = 1.0f
I don't know why holograms is missing...
Should I set another one?
this is my code.
using UnityEngine;
using UnityEngine.UI;
using System.Collections;
using System.Linq;
if WINDOWS_UWP
using Windows.Storage;
using Windows.System;
using System;
using System.IO;
endif
public class VideoRecording : MonoBehaviour {
static readonly float MaxRecordingTime = 5.0f; VideoCapture m_VideoCapture = null; float m_stopRecordingTimer = float.MaxValue; // Use this for initialization void Start() { StartVideoCaptureTest(); } void Update() { if (m_VideoCapture == null || !m_VideoCapture.IsRecording) { return; } if (Time.time > m_stopRecordingTimer) { m_VideoCapture.StopRecordingAsync(OnStoppedRecordingVideo); } } void StartVideoCaptureTest() { Resolution cameraResolution = VideoCapture.SupportedResolutions.OrderByDescending((res) => res.width * res.height).First(); Debug.Log(cameraResolution); float cameraFramerate = VideoCapture.GetSupportedFrameRatesForResolution(cameraResolution).OrderByDescending((fps) => fps).First(); Debug.Log(cameraFramerate); VideoCapture.CreateAsync(false, delegate (VideoCapture videoCapture) { if (videoCapture != null) { m_VideoCapture = videoCapture; Debug.Log("Created VideoCapture Instance!"); CameraParameters cameraParameters = new CameraParameters(); cameraParameters.hologramOpacity = 1.0f; cameraParameters.frameRate = cameraFramerate; cameraParameters.cameraResolutionWidth = cameraResolution.width; cameraParameters.cameraResolutionHeight = cameraResolution.height; cameraParameters.pixelFormat = CapturePixelFormat.BGRA32; m_VideoCapture.StartVideoModeAsync(cameraParameters, VideoCapture.AudioState.ApplicationAndMicAudio, OnStartedVideoCaptureMode); } else { Debug.LogError("Failed to create VideoCapture Instance!"); } }); } void OnStartedVideoCaptureMode(VideoCapture.VideoCaptureResult result) { Debug.Log("Started Video Capture Mode!"); string timeStamp = Time.time.ToString().Replace(".", "").Replace(":", ""); string filename = string.Format("TestVideo_{0}.mp4", timeStamp); string filepath = System.IO.Path.Combine(Application.persistentDataPath, filename); filepath = filepath.Replace("/", @"\"); m_VideoCapture.StartRecordingAsync(filepath, OnStartedRecordingVideo); } void OnStoppedVideoCaptureMode(VideoCapture.VideoCaptureResult result) { Debug.Log("Stopped Video Capture Mode!"); } void OnStartedRecordingVideo(VideoCapture.VideoCaptureResult result) { Debug.Log("Started Recording Video!"); m_stopRecordingTimer = Time.time + MaxRecordingTime; } void OnStoppedRecordingVideo(VideoCapture.VideoCaptureResult result) { Debug.Log("Stopped Recording Video!"); m_VideoCapture.StopVideoModeAsync(OnStoppedVideoCaptureMode); }
Hey,
Please try change:
to:
VideoCapture.CreateAsync(true, delegate (VideoCapture videoCapture)
The Script must be attached to the Main Camera?
