How to Extract OST File without Outlook?
in General
If you want to extract OST file without Outlook installation, then just need to download and install Indya OST Extractor tool. It provides the perfect solution to extract attachments from OST files without disturbing original formatting of files. The tool also supports to extract emails, contacts, calendar from Outlook OST files into multiple file formats.
Process to Extract OST File
1. Launch the software in your Windows machine.
2. Select OST files
3. Choose file format from the saving option list
4. Select destination path and file naming option.
5. Press the next button to begin the process.
That' how can easily extract OST file without installing Outlook application in the system.
To transfer OST files to PST by using a third-party utility, OST to PST. The software is well-matched with all versions of Outlook. Its free demo version is also available to download at- https://www.sametools.com/convert/ost/
OST to PST Converter from Shoviv is an advanced tool which provides an easy solution to recover corrupted OST file and restore deleted items from OST file. It also helps to export OST to PST, EML, Office 365, Live Exchange server and MSG. Users can also try a free trial version of this tool.
Read this blog: https://shovivtools.wordpress.com/convert-ost-to-pst/
To know how to export OST files to Outlook PST format in a hassle-free manner, try a free trial version of OST to PST Converter tool. It will also help you to export OST to Office 365, Live Exchange server, EML, and MSG. https://www.downloadtopten.com/converter/ost-to-pst/
Here, I am providing you the best suggestion for conversion of OST files to PST file format on Mac. It also recovers OST file data along with whole corrupted Outlook OST email items such as - Inbox, outbox, sent mail, note, task, journals, and draft, etc. I have a great experience on working this tool. The tool simply works fast without any hurdles. It’s a great solution to your problem. I used OST to PST Converter for Mac Software first time on the suggestion of my technical head and got flawless results. This application supports all Mac OS versions. It also provides a free trial version Tool.
Visit here:- https://www.mailvita.com/ost-to-pst-converter-for-mac/
