Chapter 2: Gaze
I apologize for being a novice but how did you get pass chapter 2? How do I edit the GazeManager.cs and Cursormanager.cs file, and edit it to perform the following tasks:
1.Perform a physics raycast,
2.Store the position and normal of the raycast intersection,
3.If the raycast did not hit anything, set the position and normal to defaults.
DavidKlineMS mod
@evanjames,
There is no apology needed for being a novice. We have all been thereIn each of the gray highlighted areas of the tutorial, there is a link labeled "(show)". You can click on this link to expand the completed version of the code. If you copy all of the code listed there and paste it over everything in the corresponding file in your project, you can complete the chapter (and future chapters) if you are unsure of what specific code to write.
Since you mention that you are a novice, I highly recommend reading the code that performs the steps outlined in the tutorial (ex: Perform a physics raycast) to see how the developer accomplished the task. I find that doing this helps accelerate my personal learning as once I see how it was done, I have a better idea of where to start on my own projects.
David6 -
neerajwadhwa mod
In the inspector panel, please click on the Script GazeManager or CursorManager and that will open up these *.cs files in your editor. Then you can read through the code in these scripts that performs the aforementioned operations.
6
@evanjames,
David
@DavidKlineMS Thank you for the detailed response. Where should I place the scripts? here you can see I have the manager object and cursor object listed in the hierarchy. Is this how it should look?
@evanjames,
You are overwriting the contents of the scripts. Earlier in the tutorial they got attached to the appropriate objects.
Were you intending to post an image?
David
@DavidKlineMS
I did attached two images but apparently they did not upload completely .
