Best way to receive OSC messages?
mam
Hi, I'm trying to send Kinect Skeletal Data to the Hololens using OSC and was wondering what would be the best way to go about doing this. I noticed the Hololens Academy 240 - Sharing Holograms example uses Holotoolkit to send information across devices. Is there a simplified script for receiving data on the hololens?
Optionsneerajwadhwa mod
@mam as you mentioned in the academy code, using the CustomMessages.cs class you can send any custom data across devices. You can also look at the Sharing test scene in the HoloToolkit-Unity GitHub project for a smaller version of the code.
There are other solutions as well like Unity Networking which you can explore.
Thanks for the tip! After looking at the scripts it seems I would only need the SharingStage and CustomMessages script in the hierarchy and maybe a modified RemoteHeadManager script to update the received skeletal data. Does that sound about right?
Did you get this to work?
