Spatial Mapping
I am trying to complete the Spatial Mapping chapter I get the errors you see below. What am I doing wrong?
OptionsHoloSheep mod
I see what looks like a space in your path name between "Evan James", if that is indeed a space, that may be the issue since Unity does not like or handle well any spaces in path or file names. It also takes issue with long path names which can cause a similar error.
I recommend you move the project to a short path that contains no spaces, perhaps something like:
C:\data\
and try opening the project from there and see if that helps or changes anything.
WinHUGR YouTube Channel -- live streamed meetings2
First, for speed reasons you probably want to do a release build, not a debug build. Secondly, the architecture of the Hololens is x86, not ARM. Try those and see what you get.
@Jarrod1937
Good call I adjusted to those settings prior to deploying but even after i switched the debug settings i now get these errors posted below.
C:\data\
