Developing for Hololens on Microsoft Surface
We're considering purchasing portable dev laptops for Hololens.
Q1. Does the Hololens Emulator run adequately on a Surface Pro 4?
If so what are the minimum specs/configuration that are required and what would you suggest?
Q2. If purchasing a Surface Book instead, what are the minimum specs required to run the Emulator without any significant lag?
Alex
  • Thank you @Joan and @Jesse_McCulloch for your answers.
    Alex
  • Thanks @mtycholaz for your response. Memory was our initial concern as well.
