Hololens and iPhone
AR123AR123
Does anyone know if you can write a Hololen app to interact with an iPhone app?
    Jarrod1937Jarrod1937 ✭✭✭
    Interact in what fashion? You can always design your application to communicate to an iPhone over the network, or depending on the type of interaction (close) then bluetooth.
    @AR123 adding to what @Jarrod1937 said, an example would be that the HoloToolkit's sharing libraries are designed to be cross platform:
    The HoloToolkit.Sharing library allows applications to span multiple devices, and enables collaboration between users in the same room or working remotely. Features include:
    •Runs on any platform, and can work with any programming language
    But as Jarrod1937 pointed out, the question then becomes what do you want to do with a connection to a platform that doesn't have the Windows Holographic api support?
    It is possible, and supported, but you will need to create a scenario or potentially libraries to support something of value and interesting on the iPhone that makes use of things like the World Anchor information that gets shared.
    Awesome stuff @HoloSheep @Jarrod1937
    I guess what I’m curious to know is can an app be made on the Hololens to visually ping you (i.e. show a persons dating profile from Tinder) whenever that person is near you? …or if someone fits a criteria on LinkedIn that you are looking for and walks by you?
    edited June 2016
    I see, that would require localizing/position tracking of an arbitrary device, which is a bit more complicated. Within a certain distance iBeacon may work:
    https://en.wikipedia.org/wiki/IBeacon
    But that's assuming an app on a phone can act as an iBeacon, that I'm not entirely familiar with.
    @HoloSheep I am also interested in this topic. I was imagining turning an iPhone into a 3D space mouse, so that we can achieve "multitouch" along with gaze. Maybe a Bluetooth mouse can do similar things, except you would also need a flat surface to put the mouse on, whereas a smartphone can be used in mid-air.
    I have make a demo app ,control with iPhone.
    I'm using OSC message via UDP.
    AR123AR123
    edited August 2016
    @littlewing That's awesome! Good work...can I hire you? haha ;)
    @littlewing
    Are you using unipad for unity asset? But I build in Windows Store platform get CS0246 error.
    @decem
    Thank you for your interest.
    As you say,it does not work well as it is.
    I have developed a OSC-library that works on UWP(Hololens).
    https://github.com/littilewing/UnityOSC-HoloLens
    You have to replace Uniy-OSC in the assets with this.
    Please try it if you have a time.
    Hey @littlewing, thanks for UWP! Wonderful work!
    I've tried to use your repo and probably I am doing something wrong. I've tested on my local machine and it works fine. When I'm trying to run on Hololens it doesn't work. I will really appreciate if you guide me somehow.
    Hi @littlewing Your video Car Showroom with HoloLens -demo
    is really amazing
    Thanks
    @Gordey sorry for the late reply .i have fix some wrong code.please try it.
    https://github.com/the6th/UnityOSC-HoloLens
