Hololens Audio Input/Output
AR123AR123
Does the Hololens come with a mic input and audio output?
    @DavidKlineMS Thanks for sharing the link.
    I just checked it out and don't see anything for mic audio inputs. :neutral:
    Are you looking to access the HoloLens mic and record something to playback through the speakers?
    Holograms 212 - Voice has a section that briefly walks through recording a message.
    @AR123,
    Under Sensors, the doc says "4 microphones".
    David
    Thanks for sharing the link!
    sorta, I'm thinking more about setting up a microphone for potential use in pro audio studios.
    Hey @AR123, did you ever find a solution for this?
    @DavidKlineMS said:
    @AR123,
    Yes, HoloLens has four microphones, a set of speakers and a headphone jack.
    This page describes the hardware.
    David
    404 link.
    Does the headphone jack also support mic line in?
    Microsoft HoloLens Agency Readiness Program Partner
    Developer, Immersive Experiences at Valorem | LinkedIn Profile
    Moderator for Microsoft's open source HoloToolkit for Unity
    In place fixed the hardware documentation link. Including it here as well.
    I do not believe the headphone jack also supports mic in, I will double check.
    David
    @StephenHogdson_V said:
    @DavidKlineMS said:
    @AR123,
    David
    404 link.
    The Hololens development edition does not have or support mic line in. You have to rely on the built-in mic.
    DamienSDamienS
    edited January 2018
    Hi, is there a way to get audio output feedback ?
    My goal is to get a message like "Room Saved" after let's say saving the room mesh.
    EDIT: Once again I have found what to use after writing my question.
    There is a TextToSpeech script in the holotoolkit which seems appropriate for my design.
