Interchangeable See-through holographic lenses
Since so many have complained about the lack of FoV for the Hololens, I wonder if the MFST team has any plans on selling larger Interchangeable See-through holographic lenses...
Any one hear anything?
OptionsJarrod1937 ✭✭✭It's a complicated endeavor to make the FOV larger, let alone interchangeable. The displays are not simple lcd displays but instead are wave guides, which itself is pretty impressive. My guess is that it is what it is now because of costs, battery life (larger display, more to render for the gpu...etc), it may also result in decreased holographic density. Some of this could be remedied, but may also make the unit bulkier, and I'd say it's already on the very edge of being too bulky for those I had test it. To me it's one of the things I'd like, but I'm not sure how feasible it is right now given the specs and price point they're shooting for.5
@Jarrod1937 have you got your unit yet? Are you happy with it, so far? I'm in Wave 2, but they extended my deadline due to my disability questions.
Oh yeah, more than happy. Everyone is concerned about the FOV, but while it could be improved, the current FOV is quite acceptable, and your mind adjusts to it after a short time. Now, I barely notice the FOV, aside from times where the hologram is tall (hence my suggestion of keeping the FOV the same width but increasing the height).
In regards, to your eye issue. I had my grandpa use it, and while it was a bit hard to tell if the difficulties were due to his eyes or his age (86 and can barely use a computer), he seemed to do pretty well still. He has no vision in one eye and no peripheral vision in the other, along with it being hazy. So, aside from missing out on the stereoscopic nature of the display, I wouldn't think you'd have too much trouble.
My only concern with the device now is how versatile it is to tap into the iPhone app api.
@AR123, yep, it seems a lot of thought has already been put into the Hololens even though we're essentially in a beta test. The only thing that may give you issues is the initial calibration step where they try to identify the IPD of your eyes. This is the only step that explicitly targets each individual eye, perhaps this is what they're working on to change before they ship yours out.
In regards to using it in conjunction with an iPhone, as mentioned in the previous topic, it depends entirely on what you're attempting to do. Unity itself is pretty versatile and allows you to program c# plugins, though UWP gives a bit of trouble with older libraries (wish they would have been better with the backwards compatibility in UWP).
@Jarrod1937 > @Jarrod1937 said:
So there is a sensor scan the of eye that takes place for an initial setup?
Not the eyes per se, more so it's a simple setup procedure to try and get what the distance between your eyes are. So, it will show an image in the left eye and have you stick your finger out, same for the right eye, and from there it can glean what the distance between your eyes are for the stereoscopic separation. This can later be adjusted in the developers portal for the device.
If you're only using a single eye, the IPD (interpupillary distance) is not of any concern and can probably be any arbitrary value. Thus that portion of the setup procedure can be skipped for such users.
