Is there a way to cast the Hololens (like the video recording) to another computer or display?
Hi, when I use this amazing product, I notice that only the wearer can see the AR, other friends cannot at least be aware what is in front of the Hololens user. Is there a way in the device already to cast the realtime screen already?
    Thanks for the heads up Jarrod. It's showing as not downloadable !
    Jarrod1937Jarrod1937 ✭✭✭
    That seems to be a common issue, checkout the forum topic on that:
    https://forums.hololens.com/discussion/939/hololens-app-not-available-in-windows-app-store
    JasonJason ✭✭
    edited June 2016
    This guy's tutorial helped me out with creating a live broadcast by using the device's REST API to expose the media recorder through a web url:
    https://medium.com/truth-labs/how-to-share-your-reality-with-the-rest-of-the-world-22cea52ec07#.d3scgy3ch
    Simple instructions and takes about 5 minutes to configure once the software is downloaded and installed (assuming you encounter no problems).
    behrambehram
    edited June 2016
    Edit: I needed to change the location of my PC to USA for the app store to download the companion app successfully.
    Hit the Windows key and type Region.
    Cheers !
    End Edit
    @Jarrod1937 region has been set to US. Still no luck.Very frustrating.
    @Jason thanks for offering an alternative.
    Cheers !
    End Edit
    Now that HoloLens is available in more countries this step should not be required still...
    which one is the companion app? I just go to the store and download it?
    thxs
