Can't deploy app to HoloLens emulator, device, or over wifi (error DEP6100).
I'm following the sample projects on the HoloLens Academy and I get the following error every time I try to deploy. I installed all of the required tools (in the proper order) and have the correct system requirements and this error fails the app deployment to all of the target devices- remote machine, emulator, device. Should I see a VM running in Hyper-V before deploying? I haven't been able to track down this error with resolution yet.
Error DEP6100 : The following unexpected error occurred during bootstrapping stage 'Connecting to the device 'A2152254-0A5F-7C78-A684-1D8072A02DF5'.':
TypeLoadException - Could not load type 'Microsoft.VisualStudio.ImmersiveProjectServices.Shared.DeployLoggingStrings' from assembly 'Microsoft.VisualStudio.TailoredProjectServices, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'. Holograms
Optionskjackson ✭
I figured out the issue! I had installed Visual Studio 2015 Enterprise with the "Default" installation option, which does not include the Tools (1.3.1) and Windows 10 SDK (10.0.10586) options under "Universal Windows App Development Tools" node. I had to go into the "Add/remove programs" in Control Panel, then right click on the VS 2015 app and "Change". This allows you to Modify the installation and check the boxed for the Tools (1.3.1) and Windows 10 SDK (10.0.10586) options. Once I did this and installed the missing those missing components the HoloLens emulator worked and I was also able to deploy to the HoloLens remote device.
6
I get the same error when trying to deploy a Holographic DirectX 11 app.
Glad you fixed it and thank you for posting the solution for others.
Severity Code Description Project File Line Source Suppression State
NullReferenceException - Object reference not set to an instance of an object. HolographicApp3 IntelliSense
I have done everything which is mentioned above but still I am not able to deploy HoloLens emulator. Plus when I tried to run this app on local machine it gave me an error like app registration failed. So please help me.
