Sharing Holograms - Help!
I'm trying to get hologram sharing working in my own app, but l'm honestly shocked how poor the documentation is. Here's the steps from the academy:
- In the Project panel navigate to the HoloToolkit\Prefabs\Sharing folder.
- Drag and drop the Sharing prefab into the Hierarchy panel.
Are you kidding me? You preconfigured the entire thing, and you just drag everything in? There's a gazillion scripts and objects in there, with no explanation about which scripts does what.
The holotoolkit wiki isn't much more useful:
https://github.com/Microsoft/HoloToolkit-Unity/wiki/Sharing
SO! Can someone please put a step-by-step how to send and received holograms and messages using this service? (already got world anchors placement, serialization and deserialization down - I just need to broadcast and received them as well as other types of messages for current application state)
neerajwadhwa mod
@dotMorten trying to find the relevant portions from your post where we can help.
Option #1: If using Shared Holograms academy class:
CustomMessages.cs is the class you can edit. For example:
public enum TestMessageID defines the information you want to share in your application.Look at: public void SendHeadTransform(Vector3 position, Quaternion rotation, byte HasAnchor)
This will teach you how to broadcast those custom messages.You cannot send a message to an individual user using this prefab.
Option #2: HoloToolkit-Unity has a Sharing test scene under Sharing folder.
You can also check the README.md Tests section under Sharing which gives more details on usage.
This also uses a simple CustomMessages class. It draws block heads on remote users. You can look at the RemoteHeadManager.cs to see how we broadcast messages.
Overall:
Once you have the networking pieces initialized as shown by ImportExportAnchorManager and CustomMessages then you simply need something like this to broadcast them:this.serverConnection.Broadcast(
msg,
MessagePriority.Immediate,
MessageReliability.UnreliableSequenced,
MessageChannel.Avatar);6
Overall:
msg,
Thanks! That's a good start (and stuff that would be good to put in the holotoolkit wiki)
My case is that I already have the message broadcast and I also register to listen to the message. But I don't receive the message although through debug I did see it sent out. Any idea?
Might be my question is not clear, I make it more details here https://forums.hololens.com/discussion/2607/hololens-sharing-using-custom-message/p1?new=1
I have the same issue. Hololens never recives anything regardless of implementation. I tired UNet, custom UDP and this. Nothing. Did you get it to work?
I just want to send a simple string to the Hololens. All this is way to overhead AND requires a PC hosting the service.
