Cursor gets stuck on Object
Wzrd
Currently testing out the cursor management and Gaze in the Hololens Emulator. It seems like the cursor gets stuck on the object. Here's some of my code:
if (Hit) { // If the raycast hits a hologram, set the position and normal to match the intersection point. Position = hitInfo.point; Normal = hitInfo.normal; lastHitDistance = hitInfo.distance; focusedObject = hitInfo.collider.gameObject; //focusedObject.transform.Rotate(0, 0 * Time.deltaTime, 0, Space.World); } else { // If the raycast does not hit a hologram, default the position to last hit distance in front of the user, // and the normal to face the user. Position = gazeOrigin + (gazeDirection * lastHitDistance); Normal = gazeDirection; focusedObject = null; } if (Hit == engine) { holoComm.SetActive(true); if(Hit == holoComm) { GUI.SetActive(true); } } else { // If the raycast does not hit a hologram, default the position to last hit distance in front of the user, // and the normal to face the user. Position = gazeOrigin + (gazeDirection * lastHitDistance); Normal = gazeDirection; focusedObject = null; //focusedObject.transform.Rotate(0, speed2 * Time.deltaTime, 0, Space.World); }
@Wzrd do you have a collider on your object?
If so where is it on your Hierarchy and where are the Cursor Manager and Gaze Manager components in comparison?
What are these modifications to the GazeManager UpdateRaycast intended to do?
Have you stepped through the code to see how it is behaving and if there are any errors or failures occurring?
How will this code ever evaluate to true:
if(Hit == holoComm)
given it is nested inside this code:
if (Hit == engine)
unless engine == holoComm?
@HoloSheep The object has an Box Collider, even though it's not necessary.. Does this affect the cursor? The GazeManager is inside a Manager who contain also an Interactible script. The CursorManager is separate from this. @timg I figured out the code did not make any sense, nor gave any results, so thats fixed.
It's obviously some code error, because the cursor seems fine now. However, the objects wont become active on Gazing.. Any suggestions?
can you post a more current/fixed version of your code so we can take another look?
I found the solution, and simplified the code a bit:
Found out that setActive() does not read inactive objects on load, so I used transform.localScale to edit the scale on Gaze. Works like a charm.
