New OS Seems like it have a lot of Jitter
AR123
Noticing a lot of jittering after downloading the latest OS. Any thoughts/Ideas as to what's up?
See example:
https://youtu.be/1zrj4yLGbp0
OptionsJarrod1937 ✭✭✭
@AR123 said:
@Jarrod1937 Thanks for the heads up and fixing the video link. Still an issue though, regardless before and after.It's a general limit of all computer graphics. This is why modern games have anti-aliasing techniques (like FSAA/MSAA). However, this takes additional computation and wasn't all that uncommon in the past to not have such measures enabled, even new games and platforms still offer the ability to disable anti-aliasing if the performance requires it. I assume this is entirely intentional, as it is not needed to provide a good experience, and the computation can be used elsewhere.
Fixed video link (previous was edit URL):
https://www.youtube.com/watch?v=1zrj4yLGbp0
I believe what you're referring to is aliasing, this happens when a display is attempting to render something that has higher resolution detail than the display is capable of showing. Personally I didn't see a difference before and after with aliasing, it was there before. You may notice it more on things with contrasting details.
@Jarrod1937 True...but the issue isn't being displayed upon recording the hologram (e.g. you're not seeing what I'm seeing from the FoV). There's jittering/artifacts only on the right lens from what seems to be faulty wiring of the display. I was able to let the Microsoft team know and they're looking into it.
Maybe you can take a video with your phone through the right eye piece.
I also found some visual issues after the update of the OS. I found that the white cursor suffer issues when I move my head, which was not the case before the update (or maybe less noticeable).
So its something thet MS can certainly solve by code.
@Jarrod1937 Sorry, didn't realize we were playing "Simon says" haha ... I posted the video not realizing that it didn't show up. I'll try to record it on my phone.
