Share anchors across scenes and holograms
nash
I have a use case where I'm switching between scenes. In scene 1 the user places a menu hologram. we want to create an anchor at the location they place that menu and use it in the next scenes as the starting point for each scene. There is a 'main' hologram that we would place at that point that everything would build around.
I'm trying to get it working using world anchors and while i can get the anchor created on menu placement im not having any success in the next scene using that world anchor as the starting point for the scene.
any samples would be greatly appreciated.
This is used to create the world anchor
public class MenuPlacement : Singleton<MenuPlacement> { public bool IsPlaced { get; private set; } private bool animationPlayed = false; private WorldAnchorStore _Store; // Use this for initialization void Start() { WorldAnchorStore.GetAsync(AnchorStoreLoaded); } // Update is called once per frame void Update() { if (IsPlaced) { if (!animationPlayed) { GetComponent<MenuBase>().SendMessage("Animate"); animationPlayed = true; CreateWorldAnchor(); } } else { transform.position = Vector3.Lerp(transform.position, GetPosition(), 0.2f); } } void CreateWorldAnchor() { if (_Store == null) return; var anchor = GetComponent<WorldAnchor>(); if (anchor == null) anchor = gameObject.AddComponent<WorldAnchor>(); if(anchor.isLocated) { _Store.Save(Constants.MenuAnchor, anchor); } else { anchor.OnTrackingChanged += Anchor_OnTrackingChanged_InitialAnchor; } } private void Anchor_OnTrackingChanged_InitialAnchor(WorldAnchor self, bool located) { if (located) { _Store.Save(Constants.MenuAnchor, self); } else { Debug.Log("Failed to locate anchor"); } self.OnTrackingChanged -= Anchor_OnTrackingChanged_InitialAnchor; } void AnchorStoreLoaded(WorldAnchorStore store) { _Store = store; } public void OnSelect() { IsPlaced = true; } Vector3 GetPosition() { //Have to account for the origin being off on this model var position = Camera.main.transform.position; return position + Camera.main.transform.forward * 2; } }
This is put on the gameObject in the scenes after the menu
public class AnchorToMenu : MonoBehaviour { WorldAnchorStore _Store; bool _Anchored; // Use this for initialization void Start() { WorldAnchorStore.GetAsync(AnchorStoreReady); } void AnchorStoreReady(WorldAnchorStore store) { _Store = store; } // Update is called once per frame void Update() { if (!_Anchored) { var anchor = _Store.Load(Constants.MenuAnchor, gameObject); if (!anchor.isLocated) { anchor.OnTrackingChanged += AnchorManager_OnTrackingChanged_Attaching; } _Anchored = true; } } private void AnchorManager_OnTrackingChanged_Attaching(WorldAnchor self, bool located) { Debug.Log("anchor " + located); self.OnTrackingChanged -= AnchorManager_OnTrackingChanged_Attaching; } }
I'm working on a multi scene project where in the first scene you place objects around the room. There's UI buttons which you click on to start the main scene. I have a simple "Don't destroy on Load" script which I will attach below which maintains the objects to the next scene, however, their placement moves significantly once I load the main scene. I've tried looking at the world anchors page to see how to utilize them but I have been competeley unsuccesfull in my attempts. If you have any examples from your own projects that match my problem please help me. Thank you!
The "Don't destroy on load" script:
public class DontDestroyOnLoad : MonoBehaviour
public int currentLevel = 0;
You might want to take a look at how GalaxyExplorer does its scene management. Consider loading your scene(s) additively and keeping your Anchors alive in your base/root scene.
In addition to what Tim suggested, you can also look at the Sharing test scene in HoloToolkit-Unity for how we persist anchors even if all the clients are out of the session. As long as you have the same session ID and area this could work for you as well.
From ImportExportAnchorManager.cs:
// To keep anchors alive even if all users have left the session ...
240 // Pass in true instead of false in CreateRoom.
241 currentRoom = roomManager.CreateRoom(new XString("DefaultRoom"), roomID, false);
