DEP0001 : Unexpected Error: -2145615869 (and a workaround?)
I am getting this error quite often when attempting to deploy to the Hololens device.
or
DEP6957 : Failed to connect to device 'xxx.xxx.xxx.xxx' using
Universal Authentication. Please verify the correct remote
authentication mode is specified in the project debug settings.
0x8007274C: The network event being waited on triggered an error.
However, if I close and then reopen VS, the problem seems to be resolved. Has anyone else encountered this?
Unity 5.40b10-HTP
VS Community 2015 14.0.25.1230 Update 2
HoloSheep mod
You might try setting the Debug flag in the projects properties pane to "Uninstall and then re-install my package. All information about the application state is deleted." as mentioned in this thread to see if it helps.
The error message I was receiving was the same as the second one you list.
WinHUGR YouTube Channel -- live streamed meetings7 -
neerajwadhwa mod
@MichaelPeters thank you reporting this issue. We have documented this on the Known Issues page. This will be fixed in a future Visual Studio update.
Workaround: You can delete your compile folder where you generate your Unity VS solution. And regenerate the VS solution. OR
You can do what @HoloSheep suggested where you can click on project-> Properties -> Debug "Uninstall and then re-install my package."8
I have the same problem after a fresh install with DEP6957, it will not deploy to the hololens, I set the debug box to Uninstall and re-install. It was working fine prior to upgrading windows...
When targeting device:
"Failed to connect to '127.0.0.1' using Universal Authentication"
When targeting remote device:
"Failed to connect to '10.0.0.118' using Universal Authentication"
The other part of the error message is
0x8007274D: The network event being waited on triggered an error.
I even reset my hololens to factory settings and started over. There are no apps installed on it and I still can't deploy to it. My computer is paired to the hololens, developer mode enabled on computer and hololens.
@LeefromSeattle,
What version of Windows 10 are you running? Is it one of the Insider builds?
David
I am also facing the same issue, I have Visual studio 2015 with update 2. I tried everything but always betting "Failed to connect to '127.0.0.1' using Universal Authentication". Please help me.
@waqar Out of curiosity, did you try closing VS and rebuilding in Unity, and then opening VS and try deploying?
I tried many times, even just now I rebuilt my project in unity and open it in vs but still same error. Even I uninstalled VS, Unity, Hololens emulator and all related installations and even I deleted visual studio files from C:\Users\myuser\AppData and reinstalled everything again.
But still same problem. Please help me, I am struggling from last one week.
One more thing, please can anyone tell me about root cause of this issue? is it from unity or visual studio or windows 10 framework or from emulator?
I found easy solution for it,
open regedit and go to
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SirepClient
change value of DisableProtocol3 value to "0".
your VS will start asking for PIN again.
Hi all.
Same problem, as all above.
Dont see SirepClient in regedit? Also how did you determine this may be causing problem?
Thank you
I have the same issue. I am unable to deploy anything to my HoloLens!
i know this is a old post, but still I encountered this error recently and this solution worked like a charm - https://stackoverflow.com/questions/36384375/dep0001-unexpected-error-1988945906-while-deploying-windows-uwp-app-to-phone
