Lines render infront of buttons
I'm trying to draw lines between buttons on my UI. I'm running into an issue where the lines appear in front of the buttons (I've attached an image showing this). I've tried setting the lines to render behind the buttons (by increasing the z position of the origin/destination) but it doesn't seem to be working.
Here's the script I'm using:
using UnityEngine; // This script draws lines between elements of the Bowtie display public class DrawLine : MonoBehaviour { private LineRenderer lineRenderer; public Transform origin, destination; void Start () { lineRenderer = gameObject.GetComponent<LineRenderer>(); lineRenderer.SetWidth(.01f, .01f); lineRenderer.SetPosition(0, origin.position); lineRenderer.SetPosition(1, destination.position); } void Update() { lineRenderer.SetPosition(0, origin.position); lineRenderer.SetPosition(1, destination.position); } }
Patrick mod
np, glad you got past it.
the solution was to scooch the lineRenderer positions back a little bit.
lineRenderer.SetPosition(0, origin.position+Vector3.forward * 0.1f);
lineRenderer.SetPosition(1, destination.position + Vector3.forward * 0.1f);===
6
A couple thoughts:
1. Draw order might matter here. Draw your lines first, then the boxes.
2. Alternatively, make sure that the shader you are using to draw your lines don't draw in front of depth, and make sure that the shader drawing your boxes does draw to the depth buffer.
@Patrick
1. I made a custom version of the standard shader for the lines and set the render queue to "Background" to ensure they are rendered first, however it didn't seem to work.
2. Not sure how to check for this. Couldn't find anything relating to depth in the shader code.
You have to set LineRendererObject.sortingLayerName ... First go to Tag&Layers window and add 2d sorting layers - sort their draw order. then assign appropriate layername to line renderers. then in the inspector go to your main canvas and assign the proper sorting layer there as well. the order of the layers will decide draw. I have achieved this without shader tweaking.
@DanglingNeuron I tried your method and it still doesn't seem to work. I set the line sorting layer to "Background" and I set the canvas sorting layer to "Default". Did I do something wrong?
I forgot to mention that the lines render correctly when I run the scene in unity, they only appear in front when I run the app on the emulator.
Canvas:
Line:
In your update loop, can you try:
@Patrick Whoops meant to accept your answer. I'm an idiot. I attempted the same solution except I forgot to add it to the update function..
