Installation of HoloLens Emulator
Installation of the emulator fails about 47% of the way through the installation green ribbon. The log says the following:
Error 0x80070643: Failed to install MSI package.
Can anyone tell me what went wrong here? What is the MSI package? Is there a way to check to see if it is missing from where the installer is looking for it? How can I move ahead?
    Here's detail from the install log:
    [08A8:02C8][2016-03-18T01:58:22]i304: Verified existing payload: package_Templates at path: C:\ProgramData\Package Cache{7B461B65-4896-49DF-8BEE-F5779FEE23CA}v10.0.11082.1014\Installers\WindowsHolographicTemplates.msi.
    [08A8:02C8][2016-03-18T01:58:22]i304: Verified existing payload: package_KitsConfigurationInstaller_x86_en_us at path: C:\ProgramData\Package Cache{6EF9512B-5501-CF15-BE58-CAF32A45F712}v10.1.11082.1014\Installers\Kits Configuration Installer-x86_en-us.msi.
    [08A8:1630][2016-03-18T01:58:22]i323: Registering package dependency provider: {25309EFD-DDD3-4EF9-878C-377CEEA30A0A}, version: 10.1.11082.1014, package: package_Xde
    [08A8:1630][2016-03-18T01:58:22]i301: Applying execute package: package_Xde, action: Install, path: C:\ProgramData\Package Cache{25309EFD-DDD3-4EF9-878C-377CEEA30A0A}v10.1.11082.1014\Installers\Xde.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" KITSROOT="" ARPSYSTEMCOMPONENT="1" UserLocale="en-us" SKIPPREREQUISITECHECK="FALSE"'
    [08A8:1630][2016-03-18T01:58:39]e000: Error 0x80070643: Failed to install MSI package.
    [08A8:1630][2016-03-18T01:58:39]e000: Error 0x80070643: Failed to execute MSI package.
    [06A0:0BD4][2016-03-18T01:58:39]e000: Error 0x80070643: Failed to configure per-machine MSI package.
    [06A0:0BD4][2016-03-18T01:58:39]i000: Applied package_Xde with status 0x80070643
    [06A0:0BD4][2016-03-18T01:58:39]i000: RetryManager: Not an execute error to retry: 0x80070643
    [06A0:0BD4][2016-03-18T01:58:39]i319: Applied execute package: package_Xde, result: 0x80070643, restart: None
    [06A0:0BD4][2016-03-18T01:58:39]e000: Error 0x80070643: Failed to execute MSI package.
    [08A8:1630][2016-03-18T01:58:39]i318: Skipped rollback of package: package_Xde, action: Uninstall, already: Absent
    [06A0:0BD4][2016-03-18T01:58:39]i319: Applied rollback package: package_Xde, result: 0x0, restart: None
    [08A8:1630][2016-03-18T01:58:39]i329: Removed package dependency provider: {25309EFD-DDD3-4EF9-878C-377CEEA30A0A}, package: package_Xde
    [08A8:1630][2016-03-18T01:58:39]i351: Removing cached package: package_Xde, from path: C:\ProgramData\Package Cache{25309EFD-DDD3-4EF9-878C-377CEEA30A0A}v10.1.11082.1014\
    [08A8:1630][2016-03-18T01:58:39]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{25aec954-0206-4ebf-8826-74ef550abb31}, resume: None, restart: None, disable resume: No
    [08A8:1630][2016-03-18T01:58:39]i330: Removed bundle dependency provider: {25aec954-0206-4ebf-8826-74ef550abb31}
    [08A8:1630][2016-03-18T01:58:39]i352: Removing cached bundle: {25aec954-0206-4ebf-8826-74ef550abb31}, from path: C:\ProgramData\Package Cache{25aec954-0206-4ebf-8826-74ef550abb31}\
    [08A8:1630][2016-03-18T01:58:39]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{25aec954-0206-4ebf-8826-74ef550abb31}, resume: None, restart initiated: No, disable resume: No
    [06A0:0BD4][2016-03-18T01:58:39]i000: Setting string variable 'SetupSessionState' to value '<?xml version="1.0" encoding="utf-16"?>
    How do you even have access to the emulator/tools? It will be released March 30th :sweat:
    A few selected organizations have it. For example, Lowe's home improvement centers was announced today by Microsoft as a partner. There are others.
    Error 0x80070643 corrupted. Dot NET framework. Run the troubleshooter admin command sfc/scannow needs net .0 3.5 and 4.6 Advanced on build 14291 Windows Insider edition and send feedback
    Hi Jimbo,
    I followed your link to install_the_tools and it says "The download is coming soon." I got my beta version installed by figuring out the .cmd file was corrupted. However, I would like to get the latest build. How can I do that?
