High density spatial mapping
CurvSurfCurvSurf ✭✭
Hi all,
We have obtained the spatial mapping data for a cylindrical wall corner of about 2m x 1m as below:
How can we get a more dense and regular one, as below?:
Joon
    Hi HoloSheep,
    Thanks for your advice. :)
    We conclued the minimum inter-vertex distance of spatial mapping is about 4 mm. We might get a more dense point cloud. Then, we could recognize, detect, and measure smaller objects. With HoloLens and our middleware, the minimum size of measurable objects is about 1'.
    For our job, automatic (real-time) data processing, a post-processing is categorically excluded.
    Joon
    @CurvSurf said:
    Hi HoloSheep,
    Joon
    Hi, it will be appreciate if you could point out where to conclue the minimum inter-vertex distance of spatial mapping :)
    CurvSurfCurvSurf ✭✭
    edited May 2017
    We have tested some values of TrianglesPerCubicMeter only to know the upperbound is ca. 2000. Then, the least minimum inter-vertex distance was ca. 4 mm empirically not theoretically.
