How do you distribute private betas?
Flarb
So how does one distribute a private test build of a HoloLens app? Is there something like TestFlight for Windows Store apps? How do you even install a HoloLens app via command line if I were to just give someone the executable? I'm sure Visual Studio is doing some command line kung-fu behind the scenes to copy and install the app on the device?
Jackson modYou can generate an appx package in Visual Studio. Right click on the project in your sln, select "store", then generate appx package.
Follow the instructions and an appx package will be built. If your device is in developer mode, under the Apps tab in the developer portal, you can sideload an app by browsing for the appx package and any dependencies.
I believe you can also submit an unlisted app to the store with the ability to share a direct link to the app. You will have to check your developer dashboard to see if this is possible.6 -
Jackson mod
You can read this doc for more context:
https://msdn.microsoft.com/windows/uwp/publish/beta-testing-and-targeted-distribution6
