How to get hand position in world coordinates
I want the user to pick objects in an intuitive way and using gaze based ray casting to the object is not something I am looking for. Therefore I need to create a vector from user's left or right eye to tap position of the user's hand. In order to do this I need the World Coordinate of the user's hand not the joystick like unit cube coordinates. Is this possible?
AlexD ✭✭✭
You can only track head position not left/right eye, so that give you your gaze.
Take a look at manipulation gesture which give you hand coordinates and movement, not the joystick controls, so you do have access to relative hand movement in real space. Combine that with gaze and even though you won't be able to allow users to "pick up" an object with your hand, they can still move the object naturally with hand movements (think of the Holograms app, and how you manipulate the objects there).
I'm not entirely sure on the math here, but you should be able to calculate the world position of the hand by combining the relative hand position with the camera's position.
Thank you for your answer, however does anyone knows how to do this actually?
Have you checked converters on Internet ?
Which converters? Could you provide a link or elaborate it please?
You have several converters on Internet that convert Cartesian coordinates into others coordinate systems (or vice-versa): that can be useful if you need an exact position conversion without doing calculations.
However, looking at your situation, you'll need it for each hand's position so my previous answer won't be useful in your case.
I'm not sure of what you exactly want but if by World Coordinates you meant Spherical Coordinates here is the conversion with the camera as origin:
(xh, yh, zh) are your hand cartesian coordinates and (xm, ym, zm) are your camera cartesian coordinates (relative to the point (0, 0, 0), origin of Unity's world for example)
r = sqrt ( (xh-xm)^2 + (yh - ym)^2 + (zh - zm)^2 )
theta = arccos( (zh - zm) / r )
phi = arctan( (yh - ym) / (xh-xm) )
