How to debug HoloLens apps?
I'm getting this error when trying to debug:
The program '[4764] ModelExplorer.exe' has exited with code 255 (0xff).
I've tried following https://forums.hololens.com/discussion/833/tutorial-debugging-with-holograms-211-with-update-code-library but it doesn't seem to work. I've tried this both with an actual device and with the emulator.
Can someone post a very simple example of how to debug?
OptionsPatrick mod
What I do is:
1. I always build release/x86 for debugging.
2. I always disable just my code when prompted.
3. I always enable mixed (managed and native) debugging.
4. and I start by debug->start debugging, or just pressing the 'play' button in visual studio.In general debugging works for me. Sometimes some lines can't take breakpoints for whatever reason, so I have to set a breakpoint a few lines earlier, but once broken in debugging works as well as it does for any set of optimized code.
7
What I do is:
@Patrick, wow that worked (just tried it on the emulator)! I had forgotten about changing it to "Mixed" debugging. Also, for some reason Debug/x86 does not work but Release/x86 does work. Any idea why? It seems counterintuitive.
Unfortunately its a bug in HoloLens version of Unity 5.4 beta, hopefully this will be fixed in Build 24, or in future.
