World Anchors supposed to remember rotation?
I'm having an issue with World Anchors and rotation in Unity. I am able to save/restore the position in the world just fine. And I am wrapping the rotation function with destroy/save (same as with translation). However, when the app re-loads, although my objects are positioned correctly, they still have the same initial rotation. Isn't it supposed to remember rotation?
OptionsPatrick mod
Rotations seem to be preserved in my simple application.
Considerations:
1. anchorStore.Save returns a bool-false means that it wasn't able to save.
2. when you add the WorldAnchor component it might not be immediately located.
3. I've found that if I don't delete the old anchor from the anchor store before saving a new one, it doesn't save the new one.Here's what I'm doing:
private void GestureRec_TappedEvent(InteractionSourceKind source, int tapCount, Ray headRay) { WorldAnchor anchor = gameObject.GetComponent<WorldAnchor>(); if (anchor != null) { anchorStore.Delete(AnchorName); DestroyImmediate(anchor); } transform.position = Camera.main.transform.position + Camera.main.transform.forward * 2.0f; transform.rotation = Quaternion.FromToRotation(Vector3.forward, Camera.main.transform.forward); { anchor = gameObject.AddComponent<WorldAnchor>(); } if (anchor.isLocated) { anchorStore.Save(AnchorName, anchor); } else { anchor.OnTrackingChanged += Anchor_OnTrackingChanged; } } private void Anchor_OnTrackingChanged(WorldAnchor self, bool located) { if (located) { self.OnTrackingChanged -= Anchor_OnTrackingChanged; anchorStore.Save(AnchorName, self); } }
yes they should. let me see if this still works for me.
Considerations:
Thanks but you seem to have dropped some code between the transform.rotation line and the next curly brace?
I was destroying, was not deleting, trying again....
It's scoped funny because of cut and paste. There was an if condition that I deleted for the quick test.
Yeah, sorry. Mono has a tendency to re-write my code as I type, even inserting new 'using' statements. It's maddening.
Thanks this helped a lot!
