Whats the best way to keep a canvas object(Text) in upper left at all times?
Ive tried setting the transform position to be the same as the cursor and camera. Even though this wont give me exactly what I need. Just trying to understand the environment...
HoloSheep mod
@mhoward you might want to experiment with a few of the following scripts in the HoloToolkit:
HTH
WinHUGR YouTube Channel -- live streamed meetings6 -
behram ✭
I got a lot from the Holograms 210 Gaze tutorial:
https://developer.microsoft.com/en-us/windows/holographic/holograms_210Essentially grab the gazeOrigin & gazeDirection from the GazeManager Singleton class and multiply that by a Vector 3 to offset the text to a position you are comfortable with.
The Billboard script @HoloSheep mentioned is also a good learning resource.
Cheers,
behram5
SimpleTagalong
Tagalong
HTH
Thanks, I'll look into this...
Cheers,
behram
