Cursor from Hololens tutorial does not register onto my 3D model from .obj file. Why is that?
NhuNhu
edited July 2016 in Questions And Answers
I was successfully able to add a 3D model I have made next to the origami project (stage + 2 spheres) in the tutorial. However, I am unable to walk towards my model, or look around it from other angles. My cursor from the sample project also does not register it. Why is it not working?
    NhuNhu
    edited July 2016
    @HoloSheep I have added the box collider component to my model. it works! thank you!
    Sorry for the poor description. I meant that my hologram appeared as a 2D projection which stayed at a constant distance from my eyes no matter where i walked. I was able to fix the problem when i used a .fbx file instead of .obj though!
    Hi guys, I havve the same problem, I also added the box collider to my project after reading this. But I cant see it. The positions are like the Holograms 101 tutorial. But I dont have the lights. Could it be the problem?
    @AylinCopoglu can you attach a couple of screen shots that show you unity editor and what you are seeing as output when you run?
    Thank you HoloSheep but its already solved!! I appreciate your help!
    CascadianCascadian
    edited March 2018
    @HoloSheep Any ideas on why the cursor is not responding to my 2D polygonal collider?
