HoloLens Emulator emulates me not actually having a HoloLens
I've installed all the tools but when I run the HoloLens emulator I get:
An unhandled exception of type 'System.Management.ManagementException' occurred in XDE.exe
Additional information: Invalid class
What can I do to fix? I've tried un and reinstalling Hyper-V as well with no change.
So I did an in-place upgrade to Windows 10 and the problem seemed to go away. Thanks for your time
6
Have you tried uninstalling and reinstalling the HoloLens emulator?
yes, no change.
Okay, have you tried deleting the virtual machine from hyper-v manager? Is there any other debug spew?
I didn't see anything specific to HoloLens in hyper-v manager I deleted the only VM that was there. Do I need to re-add it?
No other debug spew that I can find.
Visual Studio should recreate the VM the next time to try to deploy to the emulator.
so i actually can deploy a hololens project to the Mobile Emulator 10.0 but switching to HoloLens Emulator crashes and never shows up in Hyper-V Manager
okay, can you check event viewer (start->run, eventvwr.msc)
In the windows logs under application XDE or VS may have written a call stack into an event.
sounds like this...
From hyper-v can you try deleting your virtual switches? You might only need to delete the two that reference emulator. VS should remake them when you try to launch the emulator again.
(You get to the virtual switch UI from hyper-v manager, there's a virtual switch manager link on the right).
I've deleted the one virtual network switch that was there. No change, still can't run the HoloLens emulator. The HoloLens emulator has never appeared in hyper-v, I think it crashes out before it ever gets added.
Yeah, I think it's crashing trying to make the VM. Can you create a VM through the Hyper-V manager?
(And I understand this is a pain, but I don't really know what's wrong.)
Okay. that works.
